What size tires
Old Jun 30, 2009 | 02:03 PM
65Rocky's Avatar
65Rocky
Default What size tires
Looking for rims and tires for my 1965 GT 350 clone, I was thinking about 17 -8 in front and 17-9 in the rear.
chrome ? any thoughts
65 5.0,AOD, 9in with 3.89 true lock
Old Jun 30, 2009 | 03:41 PM
Carlos Pineiro's Avatar
Carlos Pineiro
8" wheels in front can cause handling probs and make steering more laborious. 9" rear wheels can hit the wheel well opening on bumps at high speeds unless you have custom suspension. Use the search tool above to check out threads on this subject. There's tons of info posted. Good luck.
CP
Old Jun 30, 2009 | 09:24 PM
2+2GT's Avatar
2+2GT
Rum your numbers through this chart:
Mustang Wheel and Tyre Chart
Old Jun 30, 2009 | 11:02 PM
Iskwezm's Avatar
Iskwezm
8" wheels will not cause any handling problems nor will they make steering any harder, your tire width will determine that.9" wheels will fit but your axle MUST be centered,fender lips rolled and the offset must be dead on.I forgot what it was off hand by my buddy has them on his and a stiff rear suspension. A 8" or 8.5" wheel on the reay is better choice and you can fit a 275. The front i went narrower with a 7" wheel and a 215/25/27
Old Jul 1, 2009 | 04:27 PM
Piraya33's Avatar
Piraya33
I have 17x7 front and 17x8 rear. I run 225/45/17 on the front with no problem. The larger wheels do seem to make the steering a little harder with manual steering. Good luck!
Old Jul 1, 2009 | 09:33 PM
66fstbk88's Avatar
66fstbk88
i ran 17x8 all around on my old coupe and did not have any problems at all. you can probably manage to fit 17x9 in the rear but id rather make some space for them (mini tub, shorten axle, ect...) or stick with 8. what are you tryin to do with this car? daily, show, race?
Old Jul 2, 2009 | 02:28 PM
65Rocky's Avatar
65Rocky
Thanks
I was attempting to give it a stronger look, wider in the rear chrome or SS rims, I could go with 15 in, but thought 17 in. would give it a undated look too
Old Jul 2, 2009 | 04:19 PM
eZ's Avatar
eZ
Rocky--
you can make 9in. rims fit by doing whats called a poor mans mini tub. Very very simple. This will allow you to run a 17x9 with 5 inch back spacing. To go any larger than this you have to remove the leaf springs ie coil-over suspension. here is link for poor man mini tub;
http://www.mustangdepot.com/graphics/pm-mini-tub.pdf
Dan-
2007CalSpec
Sep 9, 2015 05:37 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Sep 8, 2015 06:25 PM
M3hunter
Sep 5, 2015 03:42 PM
