AOD tv cable adjustment
Old Jul 24, 2009 | 08:12 PM
1965screamer's Avatar
1965screamer
Default AOD tv cable adjustment
When I'm driving the transmission doesnt want to shift and the engine just keeps winding up until I let off the gas then it shifts, but it shifts real hard. Does this mean I have the cable too tight or too loose?
Cody
Old Jul 24, 2009 | 09:26 PM
Randys66gt's Avatar
Randys66gt
It's too loose. This might help in the adjustment:
http://www.youtube.com/watch?v=6L3hNzxdiYw
Old Jul 24, 2009 | 09:28 PM
Randys66gt's Avatar
Randys66gt
Sorry it didn't click through. Just click on the You tube link and it will come up. Sorry
Old Jul 24, 2009 | 10:43 PM
JMD's Avatar
JMD
I know a little about SETTING Tv cables on 770R4's (GM SORRY) but not much about AODs
What I do know is that if you set it wrong, you stand a real good chance of smoking your tranny RIGHT NOW...
Educate yourself really well on the process and GEOMETRY of the linkage, OR get a pro to to do it.
Don't take this lightly, I have smoked a 700R4 taking the TV cable SETTING lightly, and I have seen a few others smoked even after I warned some folks....
BTW, unless you did not get it yet.... a TV cable is NEVER adjusted, it is ALWAYS set.
"Adjustment" implies tinkering is ok,,,, SETTING implies a strict PROCEDURE... and you need to follow a proven procedure.
Old Jul 25, 2009 | 12:02 AM
1965screamer
Thanks Randy! Ive read a lot about it on here and other sites and Ive watched that video also. I drove it about a quarter mile up my road just to see how it was shifting. I know this isnt to be taken lightly and im not taking it lightly. Thanks guys for the help, I appreciate it.
Old Jul 25, 2009 | 11:19 AM
tempoffroad's Avatar
tempoffroad
your best bet is to hook an oil pressure gauge to it. this will hook to the test port on the passager side. you will see to 1/8'' npt plugs. it will be the top plug. when hooked up you want to have pressure set at 0-5psi at idle in neutral with warm. as soon as you give gas it should rise. at cruise you want it between 30-35psi and at wot around 85. i hope this helps.
Thunderball
15
Nov 22, 2015 11:49 PM
kevsgt
Oct 9, 2015 10:12 PM
UrS4
Oct 3, 2015 06:23 AM
breaking
Oct 2, 2015 01:27 PM
winner99
Sep 30, 2015 07:04 PM
