Ugh, very slow leak from water pump area.
I have a new water pump and water pump gasket installed as well as a new thermostat and thermostat housing gasket.
Filled it up with water to check for any leaks. First there was leaking from one of my heater hose fittings, which I fixed by tightening it down more. Second, there was a leak from the bottom of the thermostat housing; I fixed this by replacing the gasket and it appears to no longer leak.
Now I see a very, very slow accumulation of water on a hump on top of the timing chain cover, right below the water pump.
I don't know if this is a stupid question, but what can I do about this short of just removing the water pump and getting it a new gasket?
I also spilled a little water from the thermostat housing when I replaced its gasket, any chance in 100 degree weather that this could be leftover water 8 hours later?
Well I haven't touched the timing chain cover, there's just water accumulating on top of it, probably draining down from the water pump.
I torqued the water pump just a little more, hopefully that will stop it
When you remove the water pump on a small block ford, enough of the timing chain cover bolts are removed that it relaxes tension on the timing chain to block gasket. If the gasket is old enough to have hardened, it will leak many times after reinstall of the water pump.
Also, I always use just a bit of rtv wiped on the surface of the water pump to hold the gasket in place and form a good seal.
Yay it looks like the leak (if there was one) has stopped Man that is definitely encouraging.
By the way, I did put a little bit of a Permatex gasket maker on the gasket when I installed it, but after that I went out and bought that blue RTV stuff.
