Can use a 95T5 in a 85
Old Jul 29, 2009 | 10:21 PM
MonsterBilly's Avatar
MonsterBilly
Default Can use a 95T5 in a 85
I was wondering if i can use a 95 t5 in a 85 fox body? i can get a trans out of a 95 cobra with low miles for a great price and my buddys t5 in his 85 was grenaded.
Old Jul 29, 2009 | 10:24 PM
1slow67's Avatar
1slow67
ROTM Moderator
Wrong part of forum.
Old Jul 29, 2009 | 10:25 PM
remicks's Avatar
remicks
You can but as long as you swap out the bellhousing and the input shaft. The 94/95 GT T5's bellhousing and input shaft were an extra inch longer to account for the modified platform.
Old Jul 29, 2009 | 10:28 PM
MonsterBilly
Thank you remicks
Old Jul 29, 2009 | 10:29 PM
MonsterBilly
And BA i know! it is posted over in the 5.0 section too i have just come rely on a few very informatives guys over here.
Old Jul 29, 2009 | 10:31 PM
1slow67's Avatar
1slow67
ROTM Moderator
I don't think I ever got a reply to a thread I made in that section, when I was rebuilding my T5.
Old Jul 29, 2009 | 11:43 PM
remicks's Avatar
remicks
I asked in that section once about a camshaft and it just turned into a not so helpful argument.
And no problem, I like to help with the little knowledge I have comparitivily to some guys on here. Really smart people on this forum.
Old Jul 30, 2009 | 09:45 AM
cprstreetmachines's Avatar
cprstreetmachines
No, keep the bellhouing. the input is longer, but you need the bell that goes with it. It's a about .200 longer than other T-5's. But if you run the same bell it will be fine.You just can't run a 95 T5 with a 90 T5 bell.
Old Jul 30, 2009 | 02:52 PM
remicks's Avatar
remicks
Sure? Everything I have read and asked about that trans when I was doing a conversion into my 65 it came back both being an inch longer than the fox's. Why would the input shaft be that much longer if the bellhousing is only .2 longer, wouldn't that make the input shaft .8 too long because the 5.0 didn't change?
From Fordmuscle.com
"Where to find a T5?
The T5 transmission is a manual five-speed transmission manufactured for Ford, by Borg Warner (now Tremec.) The T5 was offered in Mustangs, Thunderbirds, Capris, and possibly other Ford vehicls from 1983 all the way up to 1996, but you have to be careful -there are different specifications for 4-cylinder, 6-cylinder, and V8 cars. What you want is a T5 from a V8 car, ideally a Mustang. The 1983-1989 V8 T5's are rated at 265 lb.ft. of torque, while the 90-93 T5's are rated good to 300lb.ft of torque (93 Mustang Cobra T5 is rated for 310 lb.ft.) The difference is in the internal components and also the gearing. See the chart below for gearing differences. The 1994-1995 T5's are not desirable because the input shaft length and thus bellhousing depth were changed to accomodate the new SN95 Mustang body style."
Old Jul 30, 2009 | 03:51 PM
cprstreetmachines
Yep, it'll still work.....the handle will be in a different place(should have said that, sorry), but definitely work. A 302 block is a 302 block. Know what I mean ? Physically mating to the 302/289 is possible. i'd prefer it to a shorter T5. No goofy mechanisms to move the shifter back to more, or long weird goose neck shifter handle
