Making spot welds
Old Jul 6, 2005 | 03:50 PM
67coupe's Avatar
67coupe
Default Making spot welds
I am replacing the side cowl panels on my 67. The guy at the body shop said drill 1/8" holes to make my spot welds. After doing this I welded each hole from center to edge in a circle. All it did was close the hole and didn't weld to the metal behind at all. All my splicing welds where panels were butted together burned in good and strong. I am thinking I need to start with a bigger hole for the spot welds. Anyone out there done this before?
PS. I am using .023 wire with sheilding gas.
Old Jul 6, 2005 | 05:22 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Making spot welds
Best I remember, the 1/8 inch holes were about right. You just want to tack it. Sounds like you are doing well.
mtgldr
Feb 3, 2024 09:00 PM
cardsrus1
19
Sep 15, 2015 08:37 AM
algregory
Sep 11, 2015 11:44 AM
spamedic
Sep 9, 2015 12:15 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
