Cobra Wheels!
Old Aug 10, 2009 | 02:47 PM
guitarman376's Avatar
guitarman376
Default Cobra Wheels!
Looking at these two types of cobra wheels on summit. The first one is 8" wide and the second is 9" wide. Will either of this fit on my 1969 mustang with easy-to-find wheel adapters? I also plan on having 13" SSBC disk brakes up front just fyi. I appreciate your guys responses
http://www.summitracing.com/parts/FMS-M-1007-D178/
http://www.summitracing.com/parts/FMS-M-1007-R58/
Old Aug 10, 2009 | 09:25 PM
andrewmp6's Avatar
andrewmp6
You'll need a spacer something like a inch im not sure how thick tho.
Old Aug 10, 2009 | 10:10 PM
69mach1377's Avatar
69mach1377
You might want 8" wide up front and 9" on the rear. I think these are the same offset as my 2003 Mach1 Wheels, so this thread might be of help to you.
https://mustangforums.com/forum/clas...ml#post6189641
Good luck!
Old Aug 12, 2009 | 03:37 PM
guitarman376
I haven't gotten a straightforward response from any website or anything yet. It seems that the rear won't create any problems, but would 9" wide wheels (im assuming i would need wheel spacers) work on my car? By work I mean no rubbing/interference/problems etc. AND what size wheel spacers would I need for front and rear?
Old Aug 12, 2009 | 04:41 PM
OEWheelsLance's Avatar
OEWheelsLance
Former Sponsor
We carry this wheel as well. You can call and talk to Scott in sales, he is pretty familiar with fitment when you have the 5 lug conversion. 1-866-273-3651
Old Aug 12, 2009 | 08:49 PM
1slow67's Avatar
1slow67
ROTM Moderator
Do what Lance recommends
Old Aug 13, 2009 | 10:13 AM
pass1over's Avatar
pass1over
put similiar wheels, 99 cobra wheels 17x8 on my 66, had to run a spacer up front (less than an inch) and no spacer required in the rear. Could have even gone to a 8.5 or possibly a 9" wide wheel in the back with a little bit of fender tucking and playing with offsets, but there was only 1 offset available.
Old Aug 13, 2009 | 12:54 PM
69mach1377's Avatar
69mach1377
Really? You got nothing out of my post?
There is no straightforward answer. You have to take measurements, do the math, and hope it all works out. There is some risk involved and charts don't always work.
Old Aug 13, 2009 | 03:24 PM
pass1over's Avatar
pass1over
you can either poke around online and see what everyone else is doing or go get some straight edges and tape measurers and figure out exactly what you can and cant fit inside your wheels wells.
Old Aug 13, 2009 | 05:56 PM
69mach1377's Avatar
69mach1377
Exactly, if you don't invest the time, you'll likely be unhappy with the results. Either way, you have no one to blame but yourself if stuff rubs, so do it right.
Nov 10, 2015 11:39 AM
Manny92392
Oct 5, 2015 11:39 AM
Dan04COBRA
Sep 30, 2015 11:46 AM
mungodrums
Sep 28, 2015 05:45 AM
Sparks_88
Sep 8, 2015 01:06 PM
