which shocks between these 2 would u recomend
Old Jul 7, 2005 | 01:30 AM
markrazz's Avatar
markrazz
Default which shocks between these 2 would u recomend
KYB GR-2 shocks and struts or Gabriel Red Ryder Series gas charged shock absorbers and hijackers for the back..
there about the same price which ones are better>??
Old Jul 7, 2005 | 06:38 AM
65_2plus2's Avatar
65_2plus2
Default RE: which shocks between these 2 would u recomend
Personally, I would go with the KYB shocks. But you should look into Edelbrock performance shocks also, as I have been reading a lot a good things about them lately.
lately Cheers [sm=icon_cheers.gif]
Old Jul 7, 2005 | 12:32 PM
Soaring's Avatar
Soaring
I ♥ Acer
I would go with the KYB gas adjust shocks all the way around, and do not jack that rear end up. You will get laughed at by any Mustanger out there. If your Mustang has a sagging butt, then you need new rear leaf springs. One of the unwritten laws among Mustang owners is that there can be no extension shackles, mud flaps or shocks that jack the rear up.
Old Jul 7, 2005 | 12:43 PM
Jinxed67Stang's Avatar
Jinxed67Stang
People aren't gonna like me, cause I want some lift in the back, not alot but alil higher then the front.... gotta have that muscilly car lookin stance IMO
Old Jul 7, 2005 | 01:53 PM
Dan66's Avatar
Dan66
ORIGINAL: Jinxed67Stang
...I want some lift in the back, not alot but alil higher then the front...
Not a lot of folks realize it, but when these little cars were new, their back ends sat significantly lower than their fronts. I agree though: I like mine to at least be level (if not a hair higher in the back).
As for the shocks - Edelbrocks are all they claim to be, but way expensive. I've got the GR2s on my fastback and am quite pleased with them. Soaring is indeed correct though: shocks are not meant to restore ride height - that's the springs' job.
Old Jul 7, 2005 | 02:28 PM
Jinxed67Stang
yub, they were saggers from the get go...
Great info guys anyone got any info on other brands? maybe you can list 2 or 3 more alt for him to compare will help him with his decision
Old Jul 7, 2005 | 03:21 PM
69mach1377's Avatar
69mach1377
If you want some lift, air shocks are not the best way to get it. They basically suck. Get some new springs that provide some lift or add some helper springs, which will also reduce wheel hop.
The only valid reason for lift is to clear too wide of a tire and prevent rubbing when bottoming out...IMHO.
Old Jul 7, 2005 | 05:25 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, there are Koni shocks, but too rich for my pocketbook. After new springs in the rear, do the Shelby drop in the front to get that look. Not only will you like the looks, you will enjoy better handling from both the front and the rear.
Old Jul 7, 2005 | 05:32 PM
Jinxed67Stang
[sm=exactly.gif]
Old Jul 8, 2005 | 03:09 AM
markrazz's Avatar
markrazz
i personnally like the low back and higher or parellel front end.it makes the car look mean..i was thinkin about getting the 2 inch drop or reverse eye leaf spring to get this look..anyone used this leaf sring and check my other thread on trying to get one to hawaii
baddog671
Jul 26, 2016 01:20 PM
guitarman376
Oct 11, 2015 01:47 AM
b8checker
Oct 8, 2015 12:55 PM
UrS4
Oct 3, 2015 06:23 AM
b8checker
Sep 30, 2015 07:11 AM
