first drive
Well after one year, and more that a few hours in the garage. Tomorrow I plan to drive my car around the block. The quick list of what I have done is:
replaced gas tank and fuel lines
new 3 row radiator and hoses
carb rebuilt by Pony carbs
pulled oil pan and cleaned
new urethane sway bar bushings/end links
cleaned engine top end (search for pics
replaced valve seals
new plugs, wires
pertronix ignitor
flamethrower coil
new battery
lubed cylinders with Mystery oil before starting etc.
Changed oil 3 times (so far) after abour 1-2 hours run
time each change
replaced brake lines
new master cylinder
rebuilt 10" drum brakes all around
cleaned and painted everything I touched during
rebuilds etc.
So, what should I be looking for when I take it on the street tomorrow? I figure something will probably break, so I will have my tow guy's number with me. I'm expecting to go down the block and back, that's about it. (no tags, registration, or inspection yet
Wish me luck!!!
new plugs, wires
pertronix ignitor
flamethrower coil
new battery
time each change
new master cylinder
rebuilds etc.
Wish me luck!!!
1) if it starts and runs
2) if it moves under its own power
if yes for both 1 and 2
drive it 1 mile...fix everything that breaks / doesn't work
drive it 10 miles...fix everything that breaks
drive it 100 miles...fix everything that breaks
drive it 500 miles...fix everything that breaks
drive it a 1000 miles...fix everything that breaks
Drive it anywhere
-Gun
Drive it anywhere
-Gun
Well, around the block twice, after some brake adjustments. Picked up my mother in law and daughter for the second lap.
Runs great. Sounds great. It's a 4-speed manual, and it took me a few minutes to figure out where everything is. It takes ALOT of gas to get going in first. I think I was just babying it, but I'll get used to it. Second is no problem. That's as high as I got. Nothing broke, so next time we'll go farther.
Tomorrow I'm off to DMV for registration, tags etc. I took some pics, which I'll post soon. Woo Hoo!!!
Could it be old dusty clutch?
I think I'm getting better at it. I drove it to the store for some beverages, and it was a tiny bit better, maybe. Reverse picks right up, but into first it shakes if I don't gun it a bit.
