Distributor stuck
Old Aug 24, 2009 | 11:51 PM
Canary94GT's Avatar
Canary94GT
Default Distributor stuck
I'm trying to adjust the timing in my '65 since with the vacuum advance disconnected & plugged, it reads a few degrees AFTER top dead center and it should be 6 degrees before top dead center. With the vacuum advance connected, I get like 8 degrees.
However, after I loosened the distributor hold down bolt and tried to rotate the distributor, it would not budge in either direction.
What should I do? it's so awkward to turn the distributor as I feel like I can't get a good grip on anything but the vacuum canister (which I should say is a bit loose, should I tighten it down?)
Old Aug 25, 2009 | 03:01 AM
kalli's Avatar
kalli
very important is to try and turn it. do not try and pry it up (out) before it turns. People on this forums have all broken parts of it prying it out.
I know you said you only want to turn it, but i thought i'd throw that in anyway
try lotsa WD40 or similar, let it soak. if it's still stuck some people got it turned with applying heat and some had to use brute force. If it's smart applied brute force nothing speaks against it. and yes, when done make sure the vac canister is fixed.
Old Aug 25, 2009 | 02:40 PM
Canary94GT's Avatar
Canary94GT
Awesome, I put some Kroil penetrating oil around the base of the distributor when the engine was warm last night and let it sit overnight. Tried to turn the distributor this morning when it was cold and it was easy as pie.
Thanks Kalli.
Old Aug 25, 2009 | 02:44 PM
kalli's Avatar
kalli
perfect :-)
Old Aug 25, 2009 | 09:07 PM
capri man's Avatar
capri man
kalli knows what he is doing!!
Old Aug 26, 2009 | 04:07 AM
kalli's Avatar
kalli
i actually don't really know what i'm doing most of the times. I just read the posts and learn from what others were doing wrong :-]
mrtrodonet
Sep 19, 2020 03:12 PM
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
dalehunter
Sep 25, 2015 10:51 AM
jaiidutch
Sep 14, 2015 10:29 AM
