Is my Tranny an AOD?
Old Aug 26, 2009 | 04:39 PM
68MustangCoupe's Avatar
68MustangCoupe
Default Is my Tranny an AOD?
Ok so I think I figured out why everything is backwards with my tranny... previous posts stated that the lever *Facing down* pointing forward towards the front would be reverse... where on MINE it's park meaning using a linkage I would have to put it in reverse for it to be in park... I got to thinking about the kick down and it said that on a C4 it's not really necessary... you just need to manually shift down on hard accels. But on AOD's it's sorta needed to not Fubar the tranny. so I went outside and counted the bolts holding the pan on... there are 14 of them... C4s I've read have 11... non-computer controlled AOD's from the 80s have 14... And I don't know how much this matters but the tranny dipstick is on the passenger side of the car.
Do I have an AOD?...
The only reason It matters is because, for now I'm just trying to get the car drivable so I can use it to drive.
Edit: Did some more looking... It might be an FMX...
Old Aug 26, 2009 | 05:24 PM
68MustangCoupe
It's an FMX... I've looked at the gasket of one and the shape, it's identical.
Yay, I have an FMX... Do THESE apsolutlely need a Kickdown Cable?
Old Aug 26, 2009 | 11:49 PM
jimmy428's Avatar
jimmy428
it will be sluggish and eventually result in transmission failure.
Old Aug 27, 2009 | 01:34 AM
68MustangCoupe
Guess I gotta get a kickdown then... Any suggestions?...
Anyone say anything about the Lokar Universals?
For that matter... How they even are supposed to be installed would be a good thing to know as well...
I think 2+2GT posted a Diagram a while back but I think that was just explaining how the kickdown lever was installed on a C4...
Old Aug 27, 2009 | 05:04 AM
andrewmp6's Avatar
andrewmp6
Unless the pan says metric its not a aod.
Old Aug 27, 2009 | 04:36 PM
68MustangCoupe
Yes. After I posted the thread, I figured out it was an FMX
treesloth
Sep 28, 2015 07:03 AM
2poor4u2
Sep 26, 2015 11:08 AM
prophotog
Sep 15, 2015 08:38 AM
jaiidutch
Sep 14, 2015 10:29 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
