Changing plugs advice
Old Aug 28, 2009 | 08:13 PM
trfcrugby's Avatar
trfcrugby
Default Changing plugs advice
I need to change the plugs on my 351c 4V in a 1969 Coupe. Is this even possible with the motor in the car? I can barely even see them around the shock towers.
Thanks...
Old Aug 28, 2009 | 09:00 PM
.boB's Avatar
.boB
It can be done, but it's a real pain. Get a spark plug socket that has a hex end. Then you can use an open end wrench on it.
Some people cut holes in the shock towers and inner fenders to gain access. I would not recommend that.
BTW, are you sure it's a 351C? Although I could be wrong, I think the first year for the C was 1970.
Old Sep 4, 2009 | 01:28 AM
trfcrugby's Avatar
trfcrugby
Yeah, I got the motor out of a 1970 Cougar. Looks nice in the car, but it is a tight fit.
Old Sep 4, 2009 | 09:20 AM
Stepman's Avatar
Stepman
It's not as bad as it looks. I use a plug socket with a short ratchet on the pass side and the front 2 on the drivers side. Then add a 3 inch extension for the back 2 on drivers side. It can be a pain though, with certain headers.EDIT;NVM...didn't notice the c there but should be similar....
yourmom6990
3.7L V6 Technical Discussions
Oct 14, 2015 10:08 PM
Stilz
Aug 18, 2015 09:40 AM
OBleedingMe
Aug 8, 2015 12:02 PM
