cfm requirements
Old Sep 15, 2009 | 08:56 AM
kalli's Avatar
kalli
Default cfm requirements
Hi all,
i'm about to put together a little calculator (a windows application), that will be free.
Mainly for my own use, but can be distributed once finished (it will be a while as I only get to it when bored).
So the question is, how would you calculate required cfm.
The most common one in use is:
cfm = (RPM * CID) / 3456
with that I believe however that if dual plane manifold is in use this value should be increased by about 10% maybe (at least I read that somehwere).
If someone would buy a vacuum secondary carb (which effectively is a variable cfm size carb, this value could be further increased without having driveability problems).
Maybe I should take into consideration if the boosters are straight-leg/downleg or annular in case it's a holley based carb ..?!
any ideas, what would you want to see?
I was thinking
add 10% if vacuum secondary is used
add 10% if dual plane manifold is used
PS: this calculator will include 1/8mile-weight-time-hp calculations, rpm/gear/axle/speed calculations and others
to be an allround thingie for what people might need occasionally
Old Sep 15, 2009 | 10:41 AM
kalli's Avatar
kalli
something like this ....
Old Sep 15, 2009 | 11:18 AM
Stepman's Avatar
Stepman
Where do you find the time? Sounds cool.
Old Sep 15, 2009 | 12:52 PM
67mustang302's Avatar
67mustang302
http://www.pro-system.com/pjames011900.html
Old Sep 15, 2009 | 01:00 PM
kalli's Avatar
kalli
just read through it. Thanks a million :-)
I'll use that since they know what they're talking about (that video with the plug reader was quite impressive) ...
I might add basic info to it and will reference to their site in it, so people can read.
Kalli
Old Sep 15, 2009 | 02:03 PM
my77stang's Avatar
my77stang
pretty sweet kalli, i had no idea you could make programs!
Old Sep 15, 2009 | 02:24 PM
kalli's Avatar
kalli
Jack of all trades, master of nothing :-)
Old Sep 22, 2009 | 06:55 AM
bmaytum's Avatar
bmaytum
Sounds like an interesting program.
You can also back into CFM using horsepowerd as a given amount of air is needed to go with the amount of gas needed for the power. You'd have to assume running close to perfect mixture, but these days, who can afford to do otherwise!
According to your sig, you and I found nearly the same set of parts for our 302s. What method did you use to figure your carb? I cheated and just called Holley. It all works very well.
Good luck with your program!
Brian
Vrooom
Feb 21, 2016 05:25 PM
robcy
Suspension
Oct 27, 2015 11:14 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
LiquidDrink
Sep 29, 2015 10:06 AM
