Wheels and Ride Height
Old Nov 20, 2014 | 05:14 PM
  #151
1slow67's Avatar
1slow67
ROTM Moderator
Originally Posted by 69mach1377
Anybody running US Mags Bandit wheels?
Those are some nice looking wheels.
Old Nov 24, 2014 | 03:11 PM
  #152
69mach1377's Avatar
69mach1377
Old Dec 8, 2014 | 01:24 PM
  #153
69mach1377's Avatar
69mach1377
Fronts - 235/50zr17 x 8 w/ 4.5" BS
Rears - 285/40zr18 x 9 w/ 5.9" BS minus 7/16" spacer (longer studs)
2" drop all around - cut front springs one full turn, reverse eye leaf springs
Shelby drop
Check out my new pix in the link below.
I came to this combo after sneaking up with various combos over the decades.
Old Jun 18, 2015 | 06:39 PM
  #154
cudadan2's Avatar
cudadan2
Default quick qustion
I am a new member so high to every one but I am working on a 1965 mustang with 6 cyl. my question is I read that most people are using 7 inch wheels will 8 inch not work or do I need to do some thing I am looking at 15x8 universal lug with 0 offset
Attached Thumbnails Wheels and Ride Height-kgrhqz-r-fhmyelrptbsbdpphdm-60_1.jpg
Old Jun 19, 2015 | 07:13 AM
  #155
Norm Peterson's Avatar
Norm Peterson
Poke around the 'net using "Dodgestang" as a search term. Somewhere, there's a .pdf file for the 1965-1966 years that might be of some help.
Most people aren't willing (or perhaps confident enough) to work up their own numbers to see what combinations of width and offset will fit, or to make whatever mods might be required to make them fit. The wheel vendors - AM, Tire Rack, CJ, etc. - aren't going to crowd the limits of what's possible either, because of the risk of unhappy customers and having to deal with returns. So you end up with lots of conservatively-sized wheels and almost nothing that isn't. Or you get the 'rear fitment only' note. FWIW, it's no different with the newer generations, where a large number of aftermarket wheels are actually narrower than the OE wheels that the cars came straight from the factory with.
You might try looking in the 'Suspension' and 'Wheels and Tires' sections.
Norm
Old Jun 19, 2015 | 09:28 AM
  #156
1slow67's Avatar
1slow67
ROTM Moderator
I don't see why it wouldn't work. If you aren't sure what I'd do is just order one wheel and test fit, just make sure they will allow you to return it if it doesn't fit. Or just use that wheel on the back and run 15x7 front and 15x8 rear.
Old Jun 19, 2015 | 11:23 PM
  #157
cudadan2's Avatar
cudadan2
thanks all
Old Jul 30, 2015 | 09:05 PM
  #158
Mustangs of Illinois's Avatar
2010 mustang gt 19-9.5" rims with 1" spacers.
BF Goodrich 245/40R19 tires.
No rubbing at all.
But want to lower it at least a inch in the front and rear.
Plan on putting spring spacer on the rear springs.
But how can I lower the front 1-1/12" with out replacing the springs ?
Old Jul 31, 2015 | 02:11 PM
  #159
69mach1377's Avatar
69mach1377
Cut them, but not with a torch. For mine, 1/4 coil equalled 1/2"
Old Feb 3, 2016 | 09:40 AM
  #160
Nebojsa Vujinovic Vujo's Avatar
opie, that is some big rubber you have on that 69 there! I would not have thought 18s would fit but doesn't look to be a problem at all with yours. Did you do some mods to the wells?
