Water Temp Sender
Old Sep 17, 2009 | 02:06 PM
Billkubi's Avatar
Billkubi
Default Water Temp Sender
Where can I get the correct sender for a 68 coupe with a 289?
All the local stores sell me what they say is the right one but none of them work. This car has the 6 volt regulated gauges and I need one with between 10 ohms hot and 70 OHMS cold.
I have 5.5 volts right at the connector plug.
Everything locally is between 150 and 240 ohms and does not work
Old Sep 17, 2009 | 02:07 PM
urban_cowboy's Avatar
urban_cowboy
Have you called or looked at NPD?
Old Sep 17, 2009 | 02:38 PM
2+2GT's Avatar
2+2GT
Same junk.
You might be able to have one recalibrated:
http://www.gate.net/~foliva/sender.htm
Old Sep 17, 2009 | 04:42 PM
bodyputtyless's Avatar
bodyputtyless
Have you tried Ford? My local dealership still has many parts for cars of that age.
Old Sep 17, 2009 | 05:10 PM
tx65coupe's Avatar
tx65coupe
I got a sending unit for my 65 from CJ and it works correctly with my factory gauges with the instrument cluster voltage regulator that is 5-6 volts. It even fits my Edelbrock intake.
When you say its not working, do you mean it doesn't work at all or the gauge reads high?
Your problem may the the ICVR. I went through a few new ones from different places and none of them worked right on my car. My original one still works. We ended up making our own electronic one. I think NPD and Paddock sell electronic ones.
Old Sep 17, 2009 | 10:28 PM
guitarman376's Avatar
guitarman376
You know, you would think that such a simple part would be easy to find. I still have yet to find a retailer/manufacturer sell me the right one, even though they always say its "the right one". I have settled on one that gives me a higher reading than it should, but technically it does work so bleh.....
Old Sep 18, 2009 | 07:29 AM
2+2GT's Avatar
2+2GT
The repair parts available might fit, and even look right, but it's a real crap shoot whether they give the right reading. I just ran-in a new built 390GT, and although the intake at the sender was a perfect 195°-200°, the gauge was 3/4 of the way to "hot".
All of the current fuel senders are crap. Glazier Nolan is working on getting a proper sender made.
Use the link I posted above, they should be able to recalibrate one to perfection.
Old Sep 19, 2009 | 03:35 PM
RedGTvert's Avatar
RedGTvert
All the new temp sensors are crap. I have yet to find one that read accurately. I finally was able to locate a NOS Autolite one, and solved my problems.
Here is one listed on Ebay right now.
http://cgi.ebay.com/ebaymotors/NOS-F...d=p3911.c0.m14
Old Sep 19, 2009 | 09:43 PM
Billkubi's Avatar
Billkubi
wow 75 bucks plus shipping for a 10.00 part, that is a bit way too mucking futch
Old Sep 19, 2009 | 09:47 PM
Billkubi's Avatar
Billkubi
When I said it is not working what I mean is that I have 5.5 volts at the sender plug connector and if I ground the wire the gauge goes to full hot, so I know the gauge is working and the wire is ok, the senders I find all have too much resitance.
I think Monday I will try the ford dealer again, I tried them for the instrument voltage regulator and was told that has not been available for the last ten years
