R-134a conversion
Old Oct 3, 2009 | 07:59 AM
JDraper's Avatar
JDraper
Originally Posted by tx65coupe
I was not aware that the York would work with 134a.
Cowboy is right. The system needs to be flushed and evacuated.
Agree. I talked with several sources about the York compressor working with 134, and the general consensus I heard was that the York compressors wouldn't work properly with the smaller molecule size of the 134 and that the higher pressures you run with 134 would eventually lead to compressor failure. I did switch our '66 over to a Sanden. Is it correct for a restoration? No. But if you're not going for an exact restoration and want your air to work, go with the Sanden.
Old Oct 3, 2009 | 04:32 PM
ic237's Avatar
ic237
Hey guys I stuck r-134a into the system. Because the car is new to me i dont know how well the r-12 performs, but the r-134a works pretty good from what I am experiencing. Again its not a mercedes ac system but it gets the job done with r-134a.
HRnB
GT350 S550 Tech
Dec 18, 2015 09:35 AM
Nov 10, 2015 11:39 AM
DCole24
Sep 11, 2015 10:50 AM
YoungStangsMan
Sep 5, 2015 07:01 PM
