Windshield Washer pump leaks
Old Jul 13, 2005 | 04:02 AM
michaeldoggrell's Avatar
michaeldoggrell
Default Windshield Washer pump leaks
Hi
I tried to connect my windshield washer pump on my 66 mustang yesterday.
All the connections were made but when i put water in the water bag it just comes flooding out of my
pump. Did anyone have a similar problem ?
Old Jul 13, 2005 | 11:14 AM
horseshoeing's Avatar
horseshoeing
Default RE: Windshield Washer pump leaks
I trash the bag and put in a much newer one in from the junkyard.
Old Jul 13, 2005 | 11:57 AM
Scott H.'s Avatar
Scott H.
Default Replacement pump available
You can get a replacement pump through any of the Mustang part vendors. If you are careful you can remove the cover and then see where it's leaking. If it's leaking through the shaft, I'd replace the pump. If it's cracked you may be able to use some epoxy to seal the crack.
Old Jul 13, 2005 | 03:53 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Replacement pump available
I'd go ahead and replace the pump and not try to repair it. Heck, they are very inexpensive.....But I would keep the bag. Gives it character.
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
wraith777
Sep 28, 2015 10:49 AM
mrappe
Sep 26, 2015 10:16 AM
