another quick q on ignition box
Old Oct 8, 2009 | 12:05 AM
longlive289s's Avatar
longlive289s
Default another quick q on ignition box
mallory ignition box says a white wire is a "trigger" and needs to "connect to points, electronic ignition amp output or to green wire of a timing accessory"
well i dont have points and dont have a timing accessory so im assuming the EIA. i guess this would this be the + wire off the distributor?
Old Oct 8, 2009 | 04:48 AM
kalli's Avatar
kalli
if you have the pertronix distributor this only has two cables as far as I know.
red and black.
the red one is to feed 12V to the module and the black one is the trigger
what distributor do you have and what mallory box. I rather check on manuals before telling you crap ;-)
Old Oct 8, 2009 | 01:40 PM
longlive289s
ya its a pertronix distributor and a mallory hyfire vi 6al. i figured i had all of em figured out but this white one is killin me
theirs 2 big ones: black and red which is batt + and ground of course
small red: connects to 12v source
orange and small back : + and - coil respectively
yellow: tach
THEN trigger wires either a points circut (white) or magnetic pickup circut (green/violet).
the green/violet i wont use since is plugs into aftermarket pickups and it doesnt come close to hooking up to anything
the white one one the other hand sounds like it would connect to an electronic ignition amplifier.....ie: electronic distributor. i got a red and black wire comin off the distributor and im assuming id snip one of those wires and splice em together. so the black one off the distributor?
Old Oct 8, 2009 | 04:44 PM
kalli's Avatar
kalli
i checked on that one, have a look if it's the right document
http://www.malloryperformance.com/pdf/6852M_6853M.pdf
you should use Figure 8 on page 6
Basically in such a way:
- heavy red and black to battery
- orange and thin black to coil. NOTHING ELSE MUST BE CONNECTED AT COIL!!!!
so you have a few cables left:
all the wires that originally went to coil+ (this includes the red one from pertronix).
like: wire from ignition switch, pertronix red, cable for electric choke or electric fuel pump activation ...
all that needs to be wired together like before. And add the small red from mallory to it. this will activate the box once you switch ignition on. most importantly: those most not be connected to the coil anymore.maybe use a bolt-on-connector to chassis or somthing (keep those wires away from chassis ground), you don't want all that dangling around. it even says "original wire that was at coil+" in the diagram.
then you have that black cable from pertronix. That connects to the white one of mallory box. this tells the box when to fire.
the magnetic pickup is not used (green/purple). don't connect antwhere
job done ...
Kalli
Old Oct 8, 2009 | 07:49 PM
longlive289s
damn i hate wiring but thanks....that clears it up a bit
actually i dont think the FAQ has this but this site is a wonder. its a msd box and a mock up on a '69 with a 351w but worked perfectly for me. good source for anyone else that got stuck in my position
http://www.cartechbooks.com/vstore/s..._ID=3553&DID=6
baddog671
Jul 26, 2016 01:20 PM
daltron
Apr 28, 2016 08:10 PM
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
