Shifter bezel cover....
Old Oct 8, 2009 | 08:41 PM
sschanz's Avatar
sschanz
Default Shifter bezel cover....
My '66 originally had a console. I removed it and decided to not have a console.
Installed carpet. Opened up my new Scott Drake shifter bezel cover and was anxious to install it. Doesn't fit. The holes in the bezel are much farther apart than what's on the metal shifter housing.
So my question, is the metal housing around the shifter the same whether console or not? I thought the only difference was the housing around it.
Old Oct 8, 2009 | 09:34 PM
sschanz's Avatar
sschanz
Looks like I need this part.
http://www.trophymustang.com/196468-...te-p-2389.html
Old Oct 9, 2009 | 12:50 AM
tx65coupe's Avatar
tx65coupe
I would keep the console. I hardly ever see them in cars at the local cruise in shows.
I think that the shifter bezel is different for non console.
http://www.mustangsunlimited.com/ite...asp?T1=ASB2+01
You probably need what you linked to as well.
Old Oct 9, 2009 | 04:32 PM
2+2GT's Avatar
2+2GT
Exactly.
The 64-68 console selector bezel is entirely different from standard. 69-73 was all the same.
Where do you live? Around here, it would be rare to see a car without a console at a show. Which is not realistic- I'd be willing to bet less than 10% of any given year had a console.
Old Oct 9, 2009 | 05:51 PM
MetalEd's Avatar
MetalEd
There is that piece and a rubber gasket that goes between it and the floor:
http://www.trophymustang.com/196566-...72c1152cfff8b5
And yes, the housing bezel is different for the non-console. I believe the shifter (rod and base) is different as well, it comes as a complete unit (housing, lever and handle) on console, where the non-console one you buy each piece separately. The shifter selector light is different as well.
I don't think I have seen the housing/well that fits into the floor (lever and transmission connect through) available as a reproduction part. You may have to look for a used one of those, but I have never specifically looked for that piece.
you should really have a diagram for this project. If you have any parts catalogs from any aftermarket mustang parts dealers, most of them show exploded views of all the parts required for the non-console cars.
Old Oct 9, 2009 | 06:17 PM
2+2GT's Avatar
2+2GT
All 64-66 auto shifters were identical, regardless if they were used with a console.
The 67-68 shifter had two brackets added if there was a console, and the lever had an eye on the front instead of a clip on the side for the indicator light. The 67-68 shifter assembly is available new.
Old Oct 10, 2009 | 05:44 AM
tx65coupe's Avatar
tx65coupe
Originally Posted by 2+2GT
Exactly.
I live in central Texas. Hardly any of the 65-68 Mustangs I see around here have the console.
carid
Jul 8, 2016 09:55 AM
firehorse02
Nov 16, 2015 11:28 AM
Explosive
Oct 2, 2015 07:45 AM
guitarman376
Sep 30, 2015 05:54 PM
junior04
Sep 28, 2015 10:53 AM
