8" or 9" rearend
Old Oct 9, 2009 | 09:18 AM
hotrod351's Avatar
hotrod351
Default 8" or 9" rearend
just wondered what rearend the 69/70 mustangs came with if they came with a 302 engine.
Old Oct 9, 2009 | 09:30 AM
kalli's Avatar
kalli
i think all 302s were 8"
Old Oct 9, 2009 | 02:56 PM
JDraper's Avatar
JDraper
Not 100% sure, but the axle tag will tell you. From a chart I have, 8" rears start with WCx-xx or WDx-xx or WEA-xx. 9" rears start with WEB-xx and down.
You can also tell by the bolt pattern. This is the pattern for a Ford 8" rear:
And this is the pattern for a 9" rear
Old Oct 9, 2009 | 03:08 PM
kalli's Avatar
kalli
if you are actually at the car it's very easy to tell. if you can access all carrier bolts with a wrench and socket it's 8". if you need a spanner for one of them (pinion carrier is in the way) then it's 9". but yes. the picture shows the 9"n being more roundy which it is
67LimeCoupe
Sep 30, 2015 04:46 PM
67LimeCoupe
Sep 21, 2015 06:34 PM
67LimeCoupe
Sep 2, 2015 08:02 AM
jhutch
Aug 19, 2004 05:57 PM
S_man_9
Aug 13, 2004 12:32 PM
