lowering kit preferences
Old Oct 9, 2009 | 04:45 PM
clean66's Avatar
clean66
Default lowering kit preferences
anyone have a decent quality and decent priced, drop kit for a 66?! nothing to much maybe a 2/4 drop?
Old Oct 9, 2009 | 06:24 PM
2+2GT's Avatar
2+2GT
Before you do that, relocate the upper control arms down 1". It'll lower the car 5/8", and noticeably improve handling.
http://site.cobranda.com/tech/aarms.pdf
Old Oct 9, 2009 | 06:42 PM
restomod@16's Avatar
restomod@16
Are you saying you're trying to lower the car 2-4"!? Because that is impossibly rediculous. I can understand somwhere between 0-2" but any more and you'll be rubbing and be scrapin' your undercarriage.
Old Oct 9, 2009 | 07:02 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
Yep. Sorry.
Four inches? A picture is worth a thousand words...
Old Oct 9, 2009 | 11:07 PM
Iskwezm's Avatar
Iskwezm
A 2/4" drop is NOT impossible. Mine is lowered about 2.5" in the front and close to 3" in the rear.Doesnt scrape at all
Old Oct 9, 2009 | 11:38 PM
2+2GT's Avatar
2+2GT
It would if you lived around here, I guarantee.
Old Oct 9, 2009 | 11:39 PM
eZ's Avatar
eZ
I scrape like no other...had to put some stainless steel plates to protect the exhaust
Old Oct 10, 2009 | 04:02 AM
4reboy's Avatar
4reboy
who many inches did you lower yours eZ? I can obviously tell a lot but just curious on a number.
but to address the question, to lower these cars for the Front do the Shelby drop (.5-.75" from what I know) and get 1" drop springs (620lbs or 560 or whatever you like) for the front. In the rear you can get mid-eye leak springs (1" drop) or reverse-eye leaf springs (2" drop).
Keep in mind these drop numbers are based from a brand new stock suspension, if you suspension is old and settled, new lowering springs might simply keep it the same height. If you need the car lower you can slowly cut the coils on the fronts and get stuff like lowering blocks as far as I know for the rear. But I can't see you going lower than a reverse eye in the rear and maybe a coil or so cut off in the front.
Old Oct 10, 2009 | 04:08 AM
longlive289s's Avatar
longlive289s
lol i like how you added the couch to you pic now.
heres shelby drop info which is in the FAQ
http://www.opentrackerracingproducts.com/droptemplate/
http://members.***.net/mbstang/template.jpg
http://www.nzmustang.com/TechData/armdrop.htm
in short.....drilling new holes and dropping the upper control arms
Old Oct 10, 2009 | 07:57 AM
LCC's Avatar
LCC
Mine is lowered 3" all around.. But we made sure everything is tucked up tight.
