trunk weatherstrip
Old Oct 17, 2009 | 08:20 PM
vescotech's Avatar
vescotech
Default trunk weatherstrip
Starting to put weatherstrip on trunk but am not sure of the orentation. The seak has a split on one side. Does anyone know if the split is turned inward or outward?
Old Oct 17, 2009 | 08:35 PM
wumarshall82's Avatar
wumarshall82
I put mine on with the slit inward because the flat part is fatter and I figured that would be on the outside to keep water from getting in and it fit in the channel better.
Old Oct 17, 2009 | 09:24 PM
vescotech's Avatar
vescotech
Thankc Marshall, I understand what you are talking about the only thing is it seams to make the corner turns better with the slit turned outward. My painter removed it so I didn't get a look at how it was on. Thanks Bret
Old Oct 17, 2009 | 10:06 PM
noroof66's Avatar
noroof66
Slit is inward.
Old Oct 17, 2009 | 10:16 PM
vescotech's Avatar
vescotech
Thanks guys
Old Oct 18, 2009 | 04:40 PM
wumarshall82
Np. Its a pain to put on but I just used painters tape to keep the seal up and inplace. Left it on for about 1 day and took it off. If the trunk is off then that would make it a lot easier.
Old Oct 18, 2009 | 06:25 PM
RWP289's Avatar
RWP289
Seam definately goes inward. You don't want to channel the water around the seam and into the trunk.
Blue masking tape works great, put it every six inches or so, closer on the corners. Start at the trunk lock area and work around to the other side. You should have a little extra, just cut it with a razor. and glue the seam.
Old Oct 18, 2009 | 06:39 PM
2+2GT's Avatar
2+2GT
True, which makes it amazing that the factory installed them with the lid already on the car.
pimp2303
Sep 17, 2015 08:45 PM
movielover40
Sep 15, 2015 10:37 AM
jink21
Sep 3, 2015 11:04 AM
MustangJourney
Sep 2, 2015 04:32 PM
inyadreems
Aug 21, 2015 09:10 AM
