Shelby drop??
Old Oct 29, 2009 | 08:36 PM
LynnBob Mustang's Avatar
LynnBob Mustang
Originally Posted by BA Mustang
I used a 1/2" bit on my 67 to do the drop.
Did you have any problems with just using the 1/2"?
Lynn
Old Oct 29, 2009 | 08:38 PM
1slow67's Avatar
1slow67
ROTM Moderator
Only on the drivers side, but I think I didn't drill straight I drilled at a slight angle on one hole.
Old Oct 29, 2009 | 08:39 PM
LynnBob Mustang
Originally Posted by Joe1967
a $15 drill bit probably wont last 4 holes......
$15 is damn expensive for one lousy bit.
Lynn
Old Oct 29, 2009 | 08:41 PM
LynnBob Mustang
Did it make the bolt bind going in or just not sit straight when seated?
Did the bolt go in loose or snug with the 1/2" hole vs. having a correctly sized 17/32" hole that the stock height hole had?
Lynn
Old Oct 29, 2009 | 09:08 PM
1slow67's Avatar
1slow67
ROTM Moderator
Yeah, the bolt got stuck in the hole and the UCA wouldn't go in until we drilled out the hole some more. The bolt went in pretty easily, wasn't really snug to me.
Old Oct 29, 2009 | 09:23 PM
67mustang302's Avatar
67mustang302
The 1" a arm drop tends to lower the front of the vehicle about 1/4" to just under 1/2" (though some of that may have to do with the accuracy of the hole driller).
And $15 isn't that much for a drill bit. $17 right now gets you a 1/2" Craftsman cobalt bit. I have some bits that are $25.
Old Oct 29, 2009 | 09:24 PM
1slow67's Avatar
1slow67
ROTM Moderator
< got 1" drop with shelby drop.
Old Oct 29, 2009 | 11:52 PM
photocliff's Avatar
photocliff
If you are going to do a project like this the right quality tool "is" the right thing to do
Old Oct 30, 2009 | 06:58 AM
xenophon121's Avatar
xenophon121
yeah you are right but it doesnot raise the front end of the car..
Old Oct 30, 2009 | 09:55 AM
2+2GT's Avatar
2+2GT
True- The 1" relocation actually lowers the front end about 5/8". That's not why you do it, though. It alters the geometry to resist rolling, and "radial tunes" the suspension to keep your modern tires more square with the road.
