Heat question
Old Oct 26, 2009 | 07:39 PM
jduvall88's Avatar
jduvall88
Default Heat question
After getting my car running again I noticed the two hoses that come into the engine through the firewall and go to the carb are awful warm. I'm not sure what these carry but I was a little concerned.
I ran the car a little tonight and same story. Is this just radiator fluid or is it something else?
Also, does anyone have a link to thermostat replacing? I'm not sure if mine works (or how to test it) so I wanted to get around to looking at replacing it before the summer
Old Oct 26, 2009 | 08:29 PM
Nick.Simonds's Avatar
Nick.Simonds
Those hoses circulate coolant to your heater to help provide warm air for your enjoyment.
Old Oct 26, 2009 | 08:37 PM
jduvall88's Avatar
jduvall88
Gothca thanks, guess I need to look into fixing that heater fan (it doesn't blow less the car runs)
Old Oct 26, 2009 | 08:43 PM
Nick.Simonds
Sooo the heater doesn't run unless the car is running? Is this correct?
If so, that is probably correct. Plus, why would you be running the heater without the car running. Won't be hot, and it will drain your battery.
Old Oct 26, 2009 | 08:51 PM
jduvall88's Avatar
jduvall88
No it only runs when the car is driving, ie if I sit at idle it blows almost no air
Old Oct 26, 2009 | 11:52 PM
MetalEd's Avatar
MetalEd
Are you saying that both of them go through the carburetor riser? That would be a problem.
Old Oct 27, 2009 | 05:59 AM
jduvall88's Avatar
jduvall88
No I was mistaken, one comes out on top of where the main line from the radiator goes in and the other under
Old Oct 27, 2009 | 08:02 AM
kalli's Avatar
kalli
hiya,
just to confrim the problem:
if your sitting there at idle and the blower (inside the car) is slow and when you rev it up the blower is running quicker and back to idle the blower is running slower again?
if that's the case your alternator might not be charging at idle and the blower demands too much power (lots of leafs stuck in there) .. ?? just an idea. check voltage over battery at idle and when revving.
PaulH2
20
Jan 31, 2016 09:48 AM
treesloth
Sep 28, 2015 07:03 AM
Ipaman
Sep 22, 2015 07:01 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
Art161
Sep 9, 2015 10:33 AM
