Floor pan caulking
I have gotten some minor rust around some of the floor pan caulking in the rear pans. I have removed the rust and caulking in those areas and put the Chassis Saver over the rust.
In doing all of this I have discovered some more of the caulking is just plain loose and not really on. Should I go ahead and remove only the loose caulk and replace it, or should I even remove what at least appears to be stuck on solid?
Thanks for any help,
Lynn
Lynn
