Fuel issue?
Old Nov 16, 2009 | 02:45 PM
bredn65's Avatar
bredn65
Ya, now that I think about it, that was a dumb question! lol New tank, and fuel lines are on the way!
Thanks again for the help guys!
Old Nov 16, 2009 | 03:59 PM
kalli's Avatar
kalli
cool. hope it gets you sorted :-)
get an inline fuel pressure gau ge while you're at it and plumb between fuel pump/filter and carburetor. close to the carb. This will show you what you're dealing with straight away
Old Nov 16, 2009 | 05:05 PM
bredn65's Avatar
bredn65
Excellent idea Kalli, thanks for the tip! You always have great ideas! Really helps us newbies out (as do all of you).
Old Nov 17, 2009 | 03:59 PM
bredn65's Avatar
bredn65
So I'm getting ready to drain the tank and make the change. Do I dump the old fuel or...? Also, should it look any different coming out?
Old Nov 17, 2009 | 04:42 PM
Gun Jam's Avatar
Gun Jam
Not sure what you mean by dump it....Try to find a place that will dispose of it for you...If none available dump it in a metal container and then burn it off in smaller quantities such as in a 1 gallon paint can. Fill the gallon can about halfway move it to an open location away from everything and toss a match into it...its not nearly as bad as it sounds it will take about 20 min to burn a 1/2 gallon. Some hippies on here might throw a fit about this advice but its better than just using it as weed killer. Hopefully you can run the tank about dry before you drain it.
Before you drain it you can bang on the bottom of the fuel tank with a fist and then drain it and look for rust deposits in the drain pan. It should look clear like vodka.
Good luck with that.
-Gun
Old Nov 18, 2009 | 01:57 AM
hiboostwoody's Avatar
hiboostwoody
The old fuel will probably work just fine as lawnmower gas. Just use a funnel with a screen in it to catch any big chunks when you pour it in.
Oct 26, 2015 05:01 PM
rocky321
Sep 15, 2015 10:00 AM
TfcCDR
Sep 14, 2015 12:08 PM
zanemoseley
Sep 6, 2015 12:58 PM
5.0 kevo
Sep 3, 2015 06:24 PM
