Hand Brake
Old Nov 24, 2009 | 04:13 PM
BeastMachine67's Avatar
BeastMachine67
Default Hand Brake
I'm just curious, have any of you guys tried doing a hand brake conversion? I wonder if it can be pulled from the foxbody mustangs or something?
Old Nov 24, 2009 | 04:19 PM
1slow67's Avatar
1slow67
ROTM Moderator
Who needs an ebrake anyway...
I wish I had mine still, I took it out when I put the new rear end.
Old Nov 24, 2009 | 05:41 PM
2+2GT's Avatar
2+2GT
I've seen it done, but somehow it always looks bogus.
Old Nov 24, 2009 | 06:00 PM
Adrenolin's Avatar
Adrenolin
I've got it installed on the hump between the bucket sets. Pretty easy install and one of the only things that didn't fight me lol. No finish chrome trim in this pic and lots that still needs to get finished however here is what it looks like with the Lokar hand e-brake installed.
Old Nov 24, 2009 | 06:51 PM
BronzeBondo's Avatar
BronzeBondo
i got have an ebrake on my 65 located on the hump as well. i got a 9 inch with 11 inch drums. unfortunately i didnt install it, the previous owner did. i believe its from a late 70's ford. ill include a picture when i get a second
Old Nov 24, 2009 | 08:20 PM
ozarks06's Avatar
ozarks06
I have a handle from an 87 Fox Mustang. It doesn't have enough pull to lock up the brakes on my Explorer rear end. It's also in the way. I'll probably go back to the under dash handle if I can figure out some cabling for the Explorer brakes.
Old Nov 24, 2009 | 09:00 PM
andrewmp6's Avatar
andrewmp6
Ozark did you try shorten the cables?
Old Nov 24, 2009 | 09:19 PM
ozarks06's Avatar
ozarks06
Yes. The problem is the geomety of the handle. The Explorer brakes require more pull than the Fox handle is designed to provide. I may find another handle but I'd like a console and the handle is in the way .
Old Nov 24, 2009 | 09:46 PM
chris66dad's Avatar
chris66dad
I installed a fox model hand brake on the hump. I am not really happy with the adjustment of the cables under the car. I followed Daze's write up. http://dazed.home.bresnan.net/e-brake
I plan on doing it over and using the Lokar set up and cables. Here is an excellent write up. You may have to join the forum to read it but it is well worth it: http://www.gearheadtalk.com/forums/s...ad.php?t=21165
Lokar handbrake has the cable ends for the Explorer brakes and it works well.
Old Nov 25, 2009 | 11:21 PM
BeastMachine67
thanks for the info guys
