Driveline question
Old Nov 25, 2009 | 12:53 PM
1slow67's Avatar
1slow67
ROTM Moderator
Originally Posted by jcoby
you can also look for a conversion u joint. if you can find one it'll let you mate the smaller I6 driveshaft to the larger 8" yoke. most auto parts can get one - you just need to know what the two sizes of u joints you need are.
I asked before I had them do my driveshaft. Then don't make a hybrid u-joint like that.
Old Nov 25, 2009 | 12:55 PM
1slow67's Avatar
1slow67
ROTM Moderator
Originally Posted by 67t5ponycoupe
I swapped a 5 lug rear into a 66 with and I6 and had to change nothing. It is worth measuring before you start just so you know.
A mustang should have 2 different driveshaft sizes and 2 different u-joints. I6 and V8. I tried mine out and it was way too small for the 8in. Something about yours is different than mine were. Either the driveshaft or rear end.
Old Nov 25, 2009 | 03:08 PM
68 Coupe's Avatar
68 Coupe
Guys,
Thanks for the information. I will get out the calipers and take some measurements from the 8" rear end. I don't think the new one even has caps on the yoke, so I will need to get those too. Anything I need to be aware of before I install this rear end? I am totally rebuilding the drum brakes, and haven't noticed any leaks or grease spots on it so I assume the seals are still good.
Thanks again,
Gordon
Old Nov 25, 2009 | 09:40 PM
jcoby's Avatar
jcoby
looking through the parts listing, it looks like the 289 and the auto 200 both used the same 1310 "special" (unequal) u joints. I'm not really sure what the I6 manual trans U joint is. It's tiny.
Old Nov 25, 2009 | 10:31 PM
1slow67's Avatar
1slow67
ROTM Moderator
That explains a lot. Yeah I was told my u-joints were inner clip ones. Which were similar to the 1210 u-joint.
Old Nov 30, 2009 | 11:46 AM
crunchyskippy's Avatar
crunchyskippy
Same here with my 67. I also have a C4, which is consistent with Jcoby's statement.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
