Cobra front break swap.
Old Nov 29, 2009 | 10:29 AM
MonsterBilly's Avatar
MonsterBilly
Default Cobra front break swap.
So i have everything i need to do this swap. I bought the kit from street or track and picked up calipers from ebay ($279 the cheapest i could findw/pads) and some slotted rotors from summit.
I am going to start it right after i get the explores rear end installed.
my question is, has anyone here done it? what type of results will i get. Will they lock up easy with hard braking?
maybe a pic or two
Old Nov 29, 2009 | 12:53 PM
hiboostwoody's Avatar
hiboostwoody
You may need an adjustable proportioning valve to set front to rear brake bias if you don't already have one.
Old Nov 29, 2009 | 07:47 PM
MonsterBilly
I bought one
thanks
so has anyone else done this?
Old Nov 30, 2009 | 04:04 AM
andrewmp6's Avatar
andrewmp6
You have to replace the master cylinder for one for disc/disc.Watch which kit you bought from them they have two one uses the vintage offset one works with newer wheels.
Old Nov 30, 2009 | 05:18 AM
BlackFlame's Avatar
BlackFlame
I did SN95 Cobra 13" brakes on my 68 with slotted rotors as well (along with other SN95 suspension stuff), and I also did disc brakes on the rear. I swapped in an 87-93 power brake booster that was for disc/disc setup ( I believe those were the years if I recall correctly from my searching).
I was used to 4 wheel drums on the car and its awesome now. Stops on a dime, doesnt pull or jump side to side and is overall really smooth.
Good luck, youll enjoy it.
Old Nov 30, 2009 | 08:46 PM
MonsterBilly
Andrew
i only bought the brackets and the centering shim. I bought the rotors and the calipers form other sources.
The difference in the kits is the HAT size on the rotors. I have new wheels so i should be good using the standard disk size.
i will also have 4w disc. i am in the process of the explorer rear end swap also.
I cant wait.
BlakcFlame
is the power booster the way to go. I was not planning on installing the booster.
Old Nov 30, 2009 | 08:54 PM
BlackFlame's Avatar
BlackFlame
Originally Posted by MonsterBilly
BlackFlame
In my opinion yes...i can honestly say going from HORRIBLE manual four wheel drum brakes to this setup..is awesome...the brakes are responsive but NOT grabby...they just feel smooth and clean..as ALL brakes should.
Nov 10, 2015 11:39 AM
Oct 7, 2015 07:02 PM
ccdguy
Sep 19, 2015 05:20 PM
Blk Vert
Sep 9, 2015 12:16 PM
Sparks_88
Sep 8, 2015 01:06 PM
