battery relocation
Old Dec 2, 2009 | 03:42 PM
TexasAxMan's Avatar
TexasAxMan
Originally Posted by urban_cowboy
Why would you want to relocate the solenoid? You would then have a bunch of cables to run to the truck instead of just one.
If your solenoid is still in the engine compartment, you have a hot/unfused cable running the full length of your car. With the solenoid in the trunk, the cable is only hot while starting, the charging wire can be fused. So, solenoid in the trunk is much safer.
Old Dec 3, 2009 | 01:40 AM
nba1341's Avatar
nba1341
I relocated mine to the passenger side trunk It was an easy move. I simply ran a large cable from the trunk to the battery terminal of the ignition solenoid which is still in the stock location. I then grounded the battery to the frame. Why would you want to relocate the solenoid? You would then have a bunch of cables to run to the truck instead of just one.
but then doesn't that big cable have constant power? is this dangerous?
Old Dec 3, 2009 | 01:43 AM
nba1341's Avatar
nba1341
if the solenoid is in the trunk you have to run all those tiny wires all the way to the back or do you keep the solenoid in the front also? and just use the trunk one to run a dead cable to the starteR?'
like pretty much the kit link posted would allow me to keep solenoid in stock location?
http://www.madelectrical.com/catalog/tm-1.shtml
Old Dec 3, 2009 | 02:14 AM
Jonk67's Avatar
Jonk67
If you leave the solenoid up front and just run the 1/0 cable from the battery to starter you still have a thick 1/0 gauge wire running the length of the car that is always hot. The issue for most is if there is an accident and the 1/0 wire gets severed it will ground and start a fire or cause the batt. to explode in the trunk (gas tank) when it grounds. I have been in a T-bone accident in a '70 that crushed the sill area where most run the 1/0 cable.
If you look at the diagram it shows the engine bay wiring in the top pic and the trunk in the bottom pic. You will need to run 3 wires to do it this way - the 1/0 to the starter, 8ga. fused from alt. pwr. and 14ga. to starter wire that was on the sol. ign. stud. If the wires get severed the fuse on the 8ga. (only constant hot wire) would blow stopping current. The 1/0 is only hot when starting -then it's dead.
Jon
Old Dec 3, 2009 | 06:41 AM
rbinck's Avatar
rbinck
Jon
The kit is for a computer controlled engine. If you are dealing with a stock engine you will also need a fourth wire for the resistor wire bypass, the I terminal. That will also require another terminal under the hood for the wire on the I terminal of the solenoid.
The dual battery solution will eliminate the need to relocate the solenoid to the trunk as the wire from the trunk is fused as well. A smaller battery could be used under the hood, if desired.
Another plus for the dual battery is if the battery under the hood should run down, the trunk battery can be used to jump start the vehicle. Or if you run the trunk battery down listening to the stereo, the vehicle can still be started. Also if you have a trunk mounted stereo power amp, it can be connected directly to the trunk battery, with remote switching from the stereo.
Old Dec 3, 2009 | 02:21 PM
LastDeadLast's Avatar
LastDeadLast
Hello everyone, long time lurker, first time poster. I have a 65 vert that I'm putting together and I finally have my trunk electrical to the point that I can show it. I relocated the battery and solenoid to the trunk as well:
I'm using a unfused 1/0 welding cable to run the starter and a 175 amp maxi-fuse that goes to a terminal block under the dash where the alternator connects to and I split off to the main fuse block and the various relays to run the fuel injection, fan and lights among other things. The battery ground exits the battery box and is mounted to a bumper bolt. It's still a work in progress, but you get the idea:
BOB ROME
Jul 26, 2023 01:54 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
logan409
Sep 26, 2015 07:43 PM
