Need flywheel help
Old Dec 2, 2009 | 02:17 PM
TexasAxMan's Avatar
TexasAxMan
Question Need flywheel help
I'm putting a T-5 from an '86 GT in my '66 coupe. I need to find a suitable flywheel. Most of the 157 tooth, 28 oz. flywheels are in the $200+ range. My car will just be a street car and will only be putting around 250-270 to the rear wheels.
Since the tranny is from an '86, can I use an '86 flywheel and just have it rebalanced? I know it would clear the bell housing, but would this work with my starter (which I still don't have).
Any help appreciated.
Old Dec 2, 2009 | 02:58 PM
2+2GT's Avatar
2+2GT
Hmmm… I would think that by the time you got a used 50oz wheel resurfaced, put a new ring gear on it, and had it altered to 28oz you could have bought a new 28oz wheel.
Old Dec 2, 2009 | 03:36 PM
TexasAxMan's Avatar
TexasAxMan
I can get a new '86 5.0 flywheel for $85 from CJ Pony Parts, haven't checked elsewhere but I assume the other vendors would have a similar item at a similar price. I have an old buddy that bought a machine shop a few years back (just ran into him over the weekend) that I could probably con into rebalancing it for cheap.
I guess what I'm really wanting to know is if my starter and such will line up and mesh properly.
Old Dec 2, 2009 | 05:38 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
157 tooth is 157 tooth new or old
Old Dec 2, 2009 | 09:39 PM
chris66dad's Avatar
chris66dad
Ebay has what you need for under 100 dollars
http://cgi.ebay.com/ebaymotors/SBF-F...Q5fAccessories
or
http://cgi.ebay.com/ebaymotors/BILLE...Q5fAccessories
Are you sure the 302 is 28 oz imbalance? 68-80 the 302 used the 28 oz imbalance and 81 and later uses the 50 oz imbalance
Good Luck and BE Safe
Ron
http://chris66dad.tripod.com
Old Dec 3, 2009 | 02:43 PM
TexasAxMan's Avatar
TexasAxMan
Thanks for the links, I don't know why I haven't been able to find those. And yes, the block and crank are '68, so I need the 28 oz. imbalance.
Old Dec 3, 2009 | 03:47 PM
chris66dad's Avatar
chris66dad
These flywheels are good for the 10 1/2 inch modern diaphragm clutches for the T5 conversion. The bolts that hold the clutch on were Metric on mine, I think 10mm and I got them from ARP.
6bangr
Feb 15, 2016 07:40 AM
junior04
Sep 28, 2015 10:53 AM
dudeguy421
Sep 24, 2015 11:16 AM
ccdguy
Sep 19, 2015 05:20 PM
ponyride00
Aug 12, 2015 01:57 PM
