carburetor adjustment
Old Dec 14, 2009 | 12:02 PM
66 coupe's Avatar
66 coupe
Default carburetor adjustment
I just replaced my stock 2bbl carburetor on my '66 289 Mustang with an aftermarket 2bbl Holley (not performance). I have the adjustments just about perfect except for a slight hesitation from a stop and the car has a slight surge above 30mph. Can someone please tell me how I can smooth this out?
Old Dec 14, 2009 | 01:33 PM
2+2GT's Avatar
2+2GT
The hesitation is probably an accelerator pump issue.
Old Dec 14, 2009 | 01:37 PM
66 coupe's Avatar
66 coupe
The Holley carb is out of the box. I wouldn't think the accelerator pump would be bad.
Old Dec 14, 2009 | 06:18 PM
jasond393's Avatar
jasond393
Not that the acc. pump is bad, you just need to change the plastic cam to vary how the pump shoots the fuel into the carb. Look here:
http://www.jegs.com/i/Holley/510/20-12/10002/-1
Old Dec 15, 2009 | 02:45 PM
jlg2002's Avatar
jlg2002
This could be several things:
1. the carb is too lean
2. the fuel pump is not producing enough flow
3. the fuel filter is dirty
4. the timing is off
If you didn't have any of the current issue before you changed carbs, then you should concentrate on the too lean condition first - adjust the idle mixture screws out a little bit more (1/8 of turn) and see how that effects the off-idle transistion. It takes awhile to dial in a carb, and you may even need to mess witht he carb's jetting. jlg
cr620
Oct 3, 2022 10:18 PM
baddog671
Jul 26, 2016 01:20 PM
Thunderball
15
Nov 22, 2015 11:49 PM
UrS4
Oct 3, 2015 06:23 AM
winner99
Sep 30, 2015 07:04 PM
