Power brake booster
Old Dec 17, 2009 | 09:29 PM
68 Coupe's Avatar
68 Coupe
Default Power brake booster
Group,
I am considering a PB booster in my 68 coupe. I am swapping out the current 4 lug front and rear end for a 5 lug (new rear end, new front end except for spindles.) I figured now would be a good time to do power brakes too. It is going to get a 302 and I am going to keep the C4 in it (currently has an I6 200.) Is there a booster that is better than another? Should I get one from NPD of Mustangs Unlimited, or is there something that would work from an Explorer or other comparable junkyard fodder?
Thanks!
Old Dec 18, 2009 | 01:00 AM
Jonk67's Avatar
Jonk67
For ease of installation I'd go with a stock type Midland or Bendix booster/MC setup from NPD, MU, etc. You never mentioned if you're going disc or drum in front/rear? You will also need to change to a PB pedal to get the braking ratio correct.
Jon
Old Dec 18, 2009 | 07:27 AM
chockostang's Avatar
chockostang
68 Coupe,
Just a note on your front spindles (C6OA). Those will accept, bolt on the 67 Mustang K/H style 4 Piston per caliper, 11 19/64" rotors Factory style Disc Brakes!!!
YES, the 6 cylinders all had C6OA spindles,
If you are considering Disc brakes you won't have to change spindles those on there are PERFECT pieces.
Dan
www.chockostangclassicmustang.com
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
Big Al's 03
Sep 15, 2015 09:05 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
DoctorScary
Sep 9, 2015 07:53 AM
Sep 8, 2015 11:50 AM
