Manual transmission identification
I have a 1967 Mustang coupe with a 289 four barrel and three speed transmission. Now, assuming that the tranny hasn't been swapped (big assumption there, I know) what transmission do I most likely have in my car? I know a little about automatics but this is the first classic Ford I've had with a manual transmission
Thanks!
Thanks!
Yup. Durable, but a PITA from a performance standpoint, and not really worth much money. I just swapped mine out in favor of a close-ratio toploader. Definitely one of the best things I've ever done to my car. The only reason I'd consider running a 3sp would be if I had 4.11 gears and didn't need to take it on the freeway.
That's probably the best idea, in your case. T5's can be found in junkyards for cheap, and the swap isn't terribly expensive. A 4sp swap is a bolt-in mod (aside from the speedo cable), but toploaders are generally more expensive and slightly harder to find. I only went with a toploader because I found one in very good condition for super cheap ($350 including Hurst shifter) and because my motor puts out just enough torque to possibly grenade a T5.
I lucked into a 4-spd toploader for 250.00 (with an original Hurst Comp shifter) but typically here NJ/PA/DE/NY area they run about 650.00 and up. A complete rebuild kit is 185.00 shipped from Toploader Heaven. The kit includes everything you'd need for a general rebuild including a number of specialized tools that make the job much easier. The instructions are provided on CD and are detailed enough that ANYONE can use them to rebuild a 4-speed toploader. If you can find a toploader I highly suggest the rebuild kit so your sure everything is in correct working order!
The unit I lucked into operated smoothly and had no damaged gears when opened and inspected. I decided to rebuild to replace all the syncros, C springs, bushings, needle bearings, gaskets, etc. Turns out that the output shaft had spun the edge splines off 80% around in 2 areas! I'd have ripped this thing apart along with a good possibility of damage to other parts of the drivetrain and car if I hadn't opted for the rebuild.
Thankfully David Kee was able to overnight me a replacement main output shaft (about 200.00) to Canada right away! OK so Customs delayed it for an extra day... but still. He had it shipped out while i was still talking to him on the phone. Personal service was great and I'd deal with him again without a 2nd thought. I understand why a few guys here talk so highly of him and his products.
Don't know if Mark at Toploader Heaven sells 3-speed rebuild kits as well as the 4-speed but I'd email or give him a call and ask. Google his name and you'll find nothing but 100% positive comments about his kits, personal support and the best damned instructions I've seen for anything car related!
I keep the original output shaft in the garage now as a reminder to inspect and double check everything. It also makes one mean club!
The 3.03 is not very trendy, but it's a very solid piece of work, actually uses some of the same internal parts as the "toploader" 4-speed.
BeatnikFink
Oct 1, 2015 08:00 PM
