Would these headers fit?
Old Dec 29, 2009 | 01:29 AM
BeastMachine67's Avatar
BeastMachine67
Default Would these headers fit?
I'm currently running a late model 5.0 motor in my '67 (caburated) and a t-5 with a cable cutch setup. One od the guys from CJ Pony parts said these headers would fit but, I'm not so sure. Is there any way I can be certain?
http://www.cjponyparts.com/product.asp?pn=EXHD6
Old Dec 29, 2009 | 01:40 AM
boots6868's Avatar
boots6868
The guys at cj's are pretty accurate with what they have and what fits what. I have 68 coupe with late model 5.0 w/ gt40p heads on it and they told me if i had the e-7 heads they could set me up but couldnt help because of the gt40p heads. as far as yours goes if your running the stock mustang heads or even the gt40 not the p then you can bet they are on the right track. I would trust them. good luck
Old Dec 29, 2009 | 01:53 AM
BeastMachine67
thanks for the info, I'll look into to it
Old Dec 29, 2009 | 10:17 AM
JamesW's Avatar
JamesW
Why wouldn't standard Heddman long tubes for a 302 work?
Old Dec 29, 2009 | 11:43 AM
109jb's Avatar
109jb
That link is for long tube headers for a 351W. Sure they will bolt to the heads, but I would say that IS NOT what you want. The 351W has a taller deck block than a 302/5.0 and the headers will hang down lower under the car by about an inch because of this. The long tubes already hang low and putting those on will be an invitation for every speed bump in the area to smack the collector. I'm with JamesW. Just get long tubes for a 302. If you get them from Summit, you won't have a problem returning them if they don't fit quite right because Summit has a good return policy. You would only be out the price of shipping.
Old Dec 29, 2009 | 03:37 PM
BeastMachine67
I can't order the one for a 302 because the 302 and 351W have a different firing order, and the late model 5.0 has the same firing order as the 351W. I would pefer some shorty headders that would give me clearance on the cable clutch and wont break the bank. But, I'm actually on the sumitt site right now looking at those heddman headers. I'm gonna give them a call and see if they have something that would work for my call.
Thanks again James and 109jb
Old Dec 29, 2009 | 04:10 PM
jonward786's Avatar
jonward786
im sorry but what does firing order have to do with headers?
Old Dec 29, 2009 | 04:38 PM
1slow67's Avatar
1slow67
ROTM Moderator
This.
Old Dec 29, 2009 | 05:05 PM
67t5ponycoupe's Avatar
67t5ponycoupe
What does it have to do with firing order?
Old Dec 29, 2009 | 08:04 PM
109jb's Avatar
109jb
Firing order has nothing to do with long tube header selection, or for that matter any equal length tube header. You see, the headers are made so that the tube length is the same from the exhaust port to the collector for ALL cylinders.
