Best Riding 1" lowering springs???
Old Jan 9, 2010 | 08:05 PM
1966-FASTBACK's Avatar
1966-FASTBACK
Default Best Riding 1" lowering springs???
i know alot of you classic mustang owners have done various improvements to your cars suspensions. i would like to know which brand of lowering springs has the best ride. i know it will be stiffer but there must be a little difference between some the the brands out there. looking for the most comfortable ride after dropping it 1".
Old Jan 9, 2010 | 11:37 PM
NuclearMuscle523's Avatar
NuclearMuscle523
SCAM ALERT! This person is known around the internet for ripping people off. You've been warned.
I'll bump it and add my question too:
Big block 1" lowering springs for a 69, where?
Old Jan 10, 2010 | 05:23 AM
tx65coupe's Avatar
tx65coupe
I have 600 rate 1 inch lowering springs from Virginia Mustang. They ride very good. My understanding is that the 620 is the harshest.
Old Jan 10, 2010 | 06:38 AM
67 evil eleanor's Avatar
67 evil eleanor
Have you dont the "Shelby Drop"? This will drop the front down about 5/8" and improve driving/handling provided that the proper alignment is done. For me, I like keeping the old original sagging springs coupled with a quality shock, then dropping the front uppers 1", most of the time it flattens the stance insted of the nose up rake. I have had trouble with the aftermarket springs that are imported from India, poor or no quality control and after taking the calipers to a set, I'm done with them. Anyway if you are going the re-spring route buy American. Also don't forget it takes time for the springs to settle, like a few weeks at least. Good luck.
Old Jan 10, 2010 | 08:12 AM
2+2GT's Avatar
2+2GT
Yes, before you do anything, do the "drop". It lowers the front end about 5/8", and dramatically improves handling due to the change in geometry.
http://site.cobranda.com/tech/aarms.pdf
Old Jan 10, 2010 | 09:44 AM
69mach1377's Avatar
69mach1377
I would have to guess that progressive rate springs would be more comfortable than standard type springs...
Old Jan 10, 2010 | 11:51 AM
LCC's Avatar
LCC
www.eatonsprings.com
They will make any ride hight and stiffness you want. Had my set made there and the price was close to "off the shelf" ones. I think they make the ones for NPD.
Old Jan 10, 2010 | 02:08 PM
Jonk67's Avatar
Jonk67
I bought the NPD 550# (5310-2B-$84) for my '67 w/289, did the Shelby/Arning 1" drop installed KYB GR-2's all around with 4 1/2 mideyes in rear and like the ride and sporty feel. Ride is not jarring or washboard, nice compromise. Later I may upgrade to better shocks (Biltsein, Koni, etc.) if I can afford and need but for <$100 for 4 shocks the KYB's work nicely. The suspension is a package of course and needs to work together like engine parts. It's also subjective I've read where some feel the 620's are rock stiff and other's like them, it's a preference and depends on what the other components are (soft/hard shocks, big sway bar, etc.).
Jon
Old Jan 17, 2010 | 11:06 AM
kylehamilton79's Avatar
kylehamilton79
Like Jon, I have pretty much the same setup on my '67. Contour 550# springs from National Parts Depot (5310-2B-$84) and KYB GR-2 shocks all the way around. I love the way my car handles after the Shelby drop and with all new front suspension pieces. It's not stiff and will corner way more than I am willing to push it. With my stock pizza cutter 205/70/14 tires on it sits pretty low, almost 2" of tire inside the front fender wells. It doesn't bottom out though. It really helps being on here to find information. I researched my suspension almost a year before finally deciding on what parts should go together. Best of luck.
Old Jan 30, 2010 | 02:06 AM
synthartist69's Avatar
synthartist69
Default Lowering springs
I bought these from Mustangsunlimited.com. I was worried that they would give me a rough ride. Actually I could barely even notice a difference!
http://cgi.ebay.com/ebaymotors/1965-...Q5fAccessories
