new here have a question ??????????
Old 01-15-2010, 07:00 PM
gqproduct11
gqproduct11's Avatar
Default new here have a question ??????????
i have a 67 mustang....just got out of the body shop........but after putting together my car they cant seem to figure out why my front lights arent working...........anyone knows any good electrician for a good price or knows where i can look to fix it
gqproduct11 is offline
Old 01-15-2010, 10:07 PM
setx69fastback
setx69fastback's Avatar
get a circuit tester and start poking wires
setx69fastback is offline
Old 01-16-2010, 07:36 AM
MustangBradley
MustangBradley's Avatar
The head light switch on these cars has always been a problem. That said, it may be just a fuse in this case. Check them above the drivers kick panel. Find a wiring diagram for your car. This will help you trace which wires get power when. When my headlight switch went bad, I could still find a sweet spot between detents that would turn on the lights. Do the parking lights work?
MustangBradley is offline
Old 01-16-2010, 02:34 PM
67t5ponycoupe
67t5ponycoupe's Avatar
Start with the simple stuff, if the lights worked before you took the car in, they most likely didn't put the car together right and the lights aren't plugged in right. They should be responsible for figuring it out.
67t5ponycoupe is offline
Old 01-16-2010, 02:35 PM
nba1341
nba1341's Avatar
headlight wiring in our cars is very simple you should be able to tackle the problem in a couple hours or less
nba1341 is offline
Old 01-22-2010, 09:49 AM
bap2217
bap2217's Avatar
welcome
bap2217 is offline
Old 01-22-2010, 10:04 AM
tx65coupe
tx65coupe's Avatar
Welcome, Sorry to hear about your delima.
I agree, first get a circuit tester or use a multimeter and start checking the wiring.
After you get that figured out, upgrade to a headlight harness with relays.
tx65coupe is offline
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: new here have a question ??????????
