Brake Overhaul?
Old Jan 29, 2010 | 03:21 PM
NuclearMuscle523's Avatar
NuclearMuscle523
SCAM ALERT! This person is known around the internet for ripping people off. You've been warned.
Default Brake Overhaul?
I got the power brakes and everything from a guy(booster, cylinder, front spindles, proportioning valve, rotors, calipers) He said he would replace the valve, calipers, cylinder of all the parts since I would be going to 4 disk, and some of the parts are junk. What should I do to cut cost? Where do I get this stuff? I've seen the write up on $200 DIY brakes, but I dunno if my spindle works or whatnot.
Old Jan 29, 2010 | 04:09 PM
racin66coupe's Avatar
racin66coupe
im kind of confused as to what you are asking. do you have all the stuff for disc brakes already?
Old Jan 29, 2010 | 04:15 PM
NuclearMuscle523
I have all the stuff, but most of it is old. I will be getting the SS lines too.
Old Jan 29, 2010 | 04:17 PM
racin66coupe
what kind of condition is it in? if it is all in good working condition i would go ahead and use that since you have it, save a few bucks and use if for the DIY rear kit
Old Jan 29, 2010 | 04:19 PM
NuclearMuscle523
But how do I know what is good until I install it?
Old Jan 29, 2010 | 04:24 PM
racin66coupe
well you wont completely, but if i was you i would go ahead and install it since you have everything. maybe someone else could chime in and tell you a way to check if stuff is good but i dont tihnk there is.
you can obviously take a look at the rotors, see what condition they are in, not cracked, nice and smooth. etc etc just some visual stuff.
Man its hard trying to keep up with 3 threads with you LOL!
Old Jan 29, 2010 | 04:43 PM
NuclearMuscle523
Lol, I was just splitting it up so people of certain expertises could help with each one.
Old Jan 29, 2010 | 05:50 PM
racin66coupe
haha no i would have done the same, just thought it was funny how after i posted in one there were 2 more that were responded! LOL
Old Jan 29, 2010 | 06:49 PM
mySAVIOReigns's Avatar
mySAVIOReigns
As for the rotors, most auto parts places like O'Reilly's will have a machine in the back - they can pull the specs for the rotors and tell how "true" the rotor is, and if it is still good.
Not a whole lot to check on a Master cylinder, spindle, and Calipers - check for cracks, pits on bearing surfaces, etc.
Good luck.
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
