Edelbrock Air Gap Dual Quad - fit and performance
With either of the Edelbrock manifolds you will need to run there carbs or find some old Carters and have them rebuilt, the Holleys will not fit on there manifolds. http://store.survivalmotorsports.com...barrel-wi.html
If it were me I would go this route. Scott
You can see the difference in the a parts catalog if they show both parts.
Try downloading NPD's early mustang parts catalog.
Look at the spacing of the carb pads
http://www.summitracing.com/parts/EDL-7535/?rtype=10
No way you would get holley's in line there. There would be other problems with turning vacuum secondary carbs sideways not to mention the throttle linkage
My winter project is a 347 that I am installing now. The short block is in and my intake is the Blue Thunder 2x4 (Carl's ford parts) with Holley vacuum 450's using Stelling & Hellings air cleaners. I have test fit this under my stock 65 hood and all fits fine. I am using Ron Morris adjustable motor mounts but not lowered ones, just regular ones needed to adjust my side-to-side a bit and small amount back for header fit. Am a ways from first start yet but if pic needed I can place the intake, carbs and cleaners for a photo
If you're trying to go for a wow factor I'd ditch the dual quad idea and go with an Inglese setup and 4x2 Webber IDA's. It'll perform much better and look much better. Of course, it will also cost an arm, a leg and your firstborn child.
Started writing this before the picture and left the line in about the air filters.
Still curious about the engines specs. Nice "winter project"!!!
