When removing shock tower tops
Old Feb 6, 2010 | 08:40 PM
nba1341's Avatar
nba1341
Default When removing shock tower tops
Ok so when you remove the 2 bolts holding down the shock will the thing spring up at you or will it slowly rise? Is it easy to push back down to bolt back down? I have never dealt with shocks nor held them and am not sure how they work.
Old Feb 6, 2010 | 08:55 PM
1slow67's Avatar
1slow67
ROTM Moderator
It will rise slowly if it rises at all. They are easy to push back down.
Old Feb 6, 2010 | 09:01 PM
67mustang302's Avatar
67mustang302
Just remember with a shock, the harder your push down, the harder it pushes back. If it pops up quickly or pushes down easily under hard pressure, then it's shot.
Old Feb 6, 2010 | 09:32 PM
nba1341's Avatar
nba1341
Ok sweet thanks
Does anybody know what shocks are ford blue and made in india
Im trying to identify my front shocks which are pretty new but there are just some numbers on them which I cant read
Old Feb 7, 2010 | 09:42 AM
racin66coupe's Avatar
racin66coupe
sound like they might be NAPA or maybethe other brand which i cant think of right now. either way there not the greatest shock out there
Old Feb 7, 2010 | 11:01 AM
65rangoon's Avatar
65rangoon
dont forget to add 'if it doesnt move at all' lol
when i replaced mine they didnt move at all. i could push the cylinder to whatever position i wanted and it would just sit there cuz there was no oil left / hole somewhere haha.
Old Feb 7, 2010 | 11:03 AM
65rangoon's Avatar
65rangoon
i have some cheapy monroes on mine for now and they are also blue.
gonna put a new set on at some point this year now that i got the rest of the suspension replaced. So yes i essentially threw away $60-80 on a set of 4 LOL
*i knew the old ones were shot and figured something was better then nothing for a summer
Old Feb 7, 2010 | 01:19 PM
67mustang302
If you want to REALLY tune the suspension, go for TCP's 2-way adjustable Vari-Shocks. 256 adjustment settings, 16 bump and 16 rebound. Make it handle like a new sports car. They're just quite pricey, but typical for a 2 way shock.
Old Feb 7, 2010 | 03:25 PM
nba1341's Avatar
nba1341
I really wish I could afford expensive shocks. I think for now I am going to go with kyb gr2 in the back and kyb gas adjust up front until I can upgrade to some adjustables to get the ride I want
Old Feb 7, 2010 | 04:51 PM
67mustang302
Be careful with using soft shocks on one end at stiff shocks on the other. Soft out back and stiff out front could cause the car to understeer quite a bit. What setup does it have?
