shocks dont fit
I just turn the wheel so I can get at the bottom of the shock more easily. The top is obviously easier to get too. It takes less time to get your arms inside the wheel well than it does to jack the car up, put stands under it, jack the control arm up....and then get your arms inside the wheel well.
The problem isn't with the way he's installing it, it's with the Edelbrock shocks. Almost everyone I've talked to with the Edelbrocks (myself included) has had the same problem. The problem is that the Edelbrocks are upside-down compared to most shocks, with the shock body at the top rather than the bottom. The shock body is simply too wide to fit inside the shock tower cap at the top.
I had to grind my shock tower caps down to clear the Edelbrocks. After some quick application of semi-gloss black, they look and work just fine.
Exactly. The mounts aren't designed to accommodate the body of a shock, so you have to modify them a bit for extra clearance. Otherwise you can't get the shock far enough up to put the hold down bracket (for lack of a better name) through the upper shock bushing, let alone bolt it down to the shock tower cap.
You think they would have designed it so the shock body and mounting bracket had a bit of space to clear for installation. I mean, it seems like all they had to do was put the bracket 1" farther away from the shock body.
On a side note have you or anyone know know had any correspondence with them as to their product not fitting?
I installed Edelbrock 33237 Classic IAS Front Shock Absorbers a couple months ago with no problems installed them with the car on the ground, but did end up jacking up the body letting the suspension drop to bolt the tops down without having to compress the shocks to much.
