Just just shuts off.
Old Feb 7, 2010 | 10:42 PM
Thunder.'s Avatar
Thunder.
Default Car just shuts off
I was at a stop light, driving my 76 for the 3rd time, and it just shut off at the stop light, it took 3 GO signals to get it to turn on again. I have no idea why, I'm not a mechanic or anything.
It shakes violently right before it shuts off, and idea why?
I know I didn't provide much clues, but I really dont know where to start.
Old Feb 7, 2010 | 10:49 PM
Gun Jam's Avatar
Gun Jam
a few minutes before it died it was running great?
What happens if from a dead stop you accelerate at 100% power through 3rd gear does it pull strong the whole way with out falling flat on its face and without blowing a cloud of smoke from the exhaust?
If yes its probably ignition system... Maybe failing points or coil
-Gun
Old Feb 7, 2010 | 10:53 PM
nba1341's Avatar
nba1341
carbon button in distributor?
I was once going 70 on the freeway when my coil decided to die and good thing I was on a hill so I could continue to neutral roll to the shoulder
Giant vaccum leak?
Timing issue caused my car to shake violently before shutting off too
Old Feb 7, 2010 | 11:08 PM
1nstysnake's Avatar
1nstysnake
hey my friend had that same problem with his 95 cobra we were installing a new cam and we put everything back including the msd distributor that friday he drove it to the track and it would always die on him anywase what happened was when we set the timing on the car the distributor lock nut was loose and caused the distributor to move a couple degrees advancing the timing and the car would have a cold start
Old Feb 8, 2010 | 03:08 AM
Thunder.'s Avatar
Thunder.
Giant vaccum leak?
How did you fix the timing issue?
Old Feb 8, 2010 | 03:48 AM
nba1341's Avatar
nba1341
Go to harbor freight and get a cheap 30 dollar timing light
Start your car and check your timing to see where your at.
What engine do you have in your car?
Old Feb 8, 2010 | 12:57 PM
Thunder.'s Avatar
Thunder.
inline 6
BOB ROME
Jul 26, 2023 01:54 PM
baddog671
Jul 26, 2016 01:20 PM
Seanam
Oct 4, 2015 10:15 AM
dalehunter
Sep 25, 2015 10:51 AM
smiller38
Sep 16, 2015 07:59 AM
