power brake conversion
Old Feb 9, 2010 | 12:30 PM
ortho1121's Avatar
ortho1121
Default power brake conversion
Have 1966 convertible with auto trans. Want to convert to power brakes, presently have manual drums. What is involved and should I also switch over to disc brakes?
Old Feb 9, 2010 | 01:36 PM
MustangBradley's Avatar
MustangBradley
My car had 4 drums when I got it back in 1987. I installed a Wilwood front disc set back in the early 90's. I think the discs are just 10 inches but they are such an improvement over the stock drums that it is not fair to compare them. I run my brakes unboosted (disc front, big drum rear) and have had no problems at all. So my point is, if you convert to boosted drums, you are not increasing your stopping power, only making it easier to push the pedal for a given amount of stopping power. Go with discs on front unboosted and you can always add the booster later if you want. Or, for a few dollars more, get the whole front kit and leave your worries in the past.
http://mustangefiswap.blogspot.com/
Old Feb 9, 2010 | 04:28 PM
2+2GT's Avatar
2+2GT
Unless you drive crazy and stupid on the street like I do, or live in the mountains, or compete in time trials on the odd weekend, you don't need discs.
You do need a good booster, and the only one worth using on a 64-66 is the OE style made by Master Power Brakes. The other "conversion" types tend to be overly sensitive and have far too high a defect rate. They sell them with single master, dual drum master, and disc/drum master. Glazier Nolan sells these, they are oddly hard to find, even on MPB's website. The bracket and lever between the booster and firewall are what make this setup smooth and reliable, as on the original. The odd master cylinder is a modern piece needed to provide the dual cylinder, as the stock iron master will not fit between the booster and the shock tower. This booster is inexpensive, easy to install, and works very well. Strangely, they advertise these as "manual trans only", which is incorrect, I have asked them about this and they said they were planning to correct the website, but so far they haven't bothered.
Old Feb 10, 2010 | 11:25 AM
cprstreetmachines's Avatar
cprstreetmachines
Yes disc's are worth it even if you don't race. They are more reliable having less parts to fail and aren't affected unevenly in wet weather amongst other things.
Old Feb 10, 2010 | 05:59 PM
chockostang's Avatar
chockostang
Did you know none of the 65 66 Mustangs with Disc Brakes were POWER, all were Straight Push, no setup, manual Disc??
To add a Power Disc booster, makes common logic, Less moving parts, great the gain, so a straight push Booster would be more efficient.
Ford deemed it unnecessary to add the booster.
Dan @
ChockoStang
Old Feb 10, 2010 | 06:03 PM
TheMarco's Avatar
TheMarco
I converted from drums to discs (front only) and it was a HUGE difference. They are manual but I don't miss the booster at all. In fact I kind of like how it brakes now, it almost feels like I have more control than in my other car that does have power brakes.
Old Feb 10, 2010 | 07:10 PM
nba1341's Avatar
nba1341
I would convert to front discs because front drums are very dangerous if you need to make a sudden stop or when it is wet outside etc etc etc
Old Feb 10, 2010 | 08:03 PM
2+2GT's Avatar
2+2GT
In a sudden stop the drum or disc comes out about the same. If you are driving the car hard, the third or fourth stop will be a problem with the drums, not so much with the discs. Your right about the water, if you drive through water discs will dry almost instantly, while drums will take a heart-stopping half-a-second. Back when all cars were drums, a skilled driver would gently tap the brakes to clear them after hitting water.
Old Feb 13, 2010 | 06:09 PM
ortho1121's Avatar
ortho1121
Default follow-up question
I know NOTHING about doing this. If I change to front discs is it just a matter of changing the brakes themselves or does it involve the brake lines and master cyclinder?
Old Feb 13, 2010 | 06:38 PM
2+2GT's Avatar
2+2GT
The lines may require alteration, and you'll need a disc MC.
I'd stick with the power boost for now.
