Engine Problems!!!
Old Jul 26, 2005 | 12:37 AM
hobbyhorse's Avatar
hobbyhorse
Default Engine Problems!!!
Can someone please tell me how to decode my engine. I'm not sure that it really is a 200ci. i dont think that this is my original engine. Also, Why is my car overheating so much? I just drove it around the block and the radiator was really hot, i already checked the water pump, and it's not that, i have no idea what's wrong with it. I also want to know what kind of cap does the radiator suppose to have the one i have says 13 lbs. Which one am i suppose to have?
Thanks in advance for any tips.
Old Jul 26, 2005 | 01:18 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Engine Problems!!!
13 lbs is the right cap for your rad. First, take out your thermostat and run the engine without it. If it runs cool, then replace the thermostat. If that doesn't do the trick, I would do a complete engine and radiator flush, then see if that helps. If not, then you may need to get a new radiator and possibly a 5 blade fan. If that doesn't help, then add the shroud and an overflow tank. Also, check your lower radiator hose to make sure it is not collapsing after a few blocks. There is a coil of wire in there to help keep that hose open, but often times its rusts out and then you have a collapsed hose. When you add the anti-freeze/distilled water mixture after a good cleaning and/or replacemant of the radiator, use about a 50-50 mixture of antifreeze/water. Also, get a bottle of a brand of additive called Wetter Water and add that to the system. Good Luck with it.
Old Jul 26, 2005 | 02:37 AM
68COOP's Avatar
68COOP
EXCELLENT ADVICE! While you got the t-stat out, replace it with a brand called Fail-Safe, and get the 160* one. It will open and stay open if it fails, so you won't be stuck somewhere till it cools off.
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
HIS S-197
Aug 10, 2015 05:47 PM
Pain.
Aug 7, 2015 10:48 PM
