Classic Auto Air vs. Vintage Air
Old Jun 2, 2010 | 05:07 AM
2+2GT's Avatar
2+2GT
Originally Posted by TexasAxMan
One thing to consider, the Vintage Air system uses the existing heater hole locations on the firewall whereas the Classic Air kit runs all of the hoses out of the current motor hole. This means you have to cover or weld up those old heater holes.
Ford put a pair of rubber plugs in the hose holes in 67-70 AC Mustangs. These plugs are still available.
Old Jun 2, 2010 | 12:02 PM
TexasAxMan's Avatar
TexasAxMan
Originally Posted by c2sc
TexasAxMan
I know this is an oldler post, but I'm looking at the vintage air kit for my restomod. I just had a couple of questions for you. How well does it work? Also, does heat come throught the a/c installed vents (does it blend the air)? Or does the heat only blow to the floor and a/c vents only blow cold air (when on the setting).
Was curious because the vintage air catalogue says "A/C exits through dashvents or our under dash louvers. Heat exits at floor."
http://www.vintageair.com/catalog09/...talog%2046.pdf
Thanks!
Nate
Vancouver, Canada
I haven't started my car yet, so I can't tell you how well it works. You should be able to blend just by adjusting the temperature lever.
Old Jun 3, 2010 | 09:34 AM
MBDiagMan's Avatar
MBDiagMan
TexasAxMan
Thanks!
Nate
Vancouver, Canada
What year model are you working on?
Old Jun 3, 2010 | 10:00 PM
c2sc's Avatar
c2sc
I'm working on my '66 Mustang with 5L efi.
Nate
Old Jun 4, 2010 | 07:48 AM
MBDiagMan's Avatar
MBDiagMan
If you haven't already bought anything I would make a reccomendation. I have been messing with auto air conditioning since my hanging around my Dad's shop when he began installing aftermarket a/c systems in 1957.
The Ford underdash unit that was commonly used in the 66 Mustang, either factory or dealer installed is a very high quality unit. MUCH higher quality than the plasticy crap that comes from todays aftermarket. The original 66 units are not hard to find and are almost always in great condition.
Use one of the original underdash units and then get a kit from someone like ackits or nostalgicautoair and with the exception of the Sanden compressor, will fit in place almost as the original. Using a Sanden compressor and a parallel flow condensor along with the high quality underdash unit will give you a good performing, high quality system that will look as if it came from the factory, at least in the interior.
There is a knockout in the firewall and a rubber grommet is available that will put the hoses through, properly sealed with minimal hassle. The Sanden mount for the dirvers side would be best and is a high quality piece with beautiful "roll of dimes" TIG welding.
This kinid of system can be had for much less than the afterthought looking units from places like Vintage air and will perform and look better.
My $0.02,
5.0muscle
Jan 11, 2016 01:17 PM
heslekrants
Sep 23, 2015 04:02 PM
JT76
Sep 20, 2015 11:32 AM
fastbackford351
Sep 12, 2015 09:42 AM
