backyard engine
Old Feb 16, 2010 | 12:38 PM
1967coupeon101's Avatar
1967coupeon101
Default backyard engine
I am doing the whole 6 to 8 conversion on my 1967 coupe, but bought the engine over 6 months ago.... I don't know much about the technical side of automobiles, just how to take apart and put together (I'll be taking some technician classes to learn more)
That engine has been sitting in a backyard since the day I bought it. Its been covered by a really heavy waterproof plastic tarp. its been through a bay area, CA winter (rain/fog/30 degrees at lowest) It ran great when I bought it.
My question is: Will the engine run? Will it be locked up and need a rebuild? is this too long of a time to leave an engine sit around?
Old Feb 16, 2010 | 01:11 PM
kalli's Avatar
kalli
if it was covered well you should be ok.
remove at least the valve covers. chances are the internals look just like what you find in there.
you should manually turn the engine (at balancer) at least twice to see if anything is seized up before you install the engine
and before you start it prime it properly, and change the oil and filter.
so just before you fire it up the first time switch everything off, remove the distributor (mark the position of rotor and housing), at the end where the distributor locks in there's a hole where you fit in the bit of an allen key. attach one into a drill and turn counterclockwise for a few minutes. that'll splash oil about everywhere inside the engine (it's turning the oilpump just like the engine would). then manually turn the engine 90 degrees, and prime again. do that for two full revolutions of engine (8 times). that's probably the best treatment she can get without pullking everything apart.
Old Feb 16, 2010 | 02:02 PM
toybreaker's Avatar
toybreaker
If I can suggest 1 additon to what Kalli said...
Before you turn it over spray/apply oil into each cylinder before you try to turn it over.
Old Feb 16, 2010 | 02:41 PM
MBDiagMan's Avatar
MBDiagMan
WARNING!!! The suggestion to squirt oil in the cylinders is a good one, but beware that you MUST blow the oil out before replacing the plugs and turning over the engine again. Too much oil or any liquid in a cylinder can cause engine damage. Oil does not compress.
Good luck with it.
Old Feb 16, 2010 | 03:02 PM
toybreaker's Avatar
toybreaker
Good luck with it.
Turn it over by hand without the plugs in it.
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
