Gas Leak at Fuel Filter
Old Feb 17, 2010 | 08:53 PM
67 horse's Avatar
67 horse
Default Gas Leak at Fuel Filter
My 67 V6 200 is leaking fuel at the fuel filter where it connects with the autolite 1100 carburetor. When I tried tightening the filter, it appears that either it is stripped or more likely the carburetor threads are stripped. Am I completely out of options on this carburetor?
Old Feb 17, 2010 | 09:45 PM
setx69fastback's Avatar
setx69fastback
not sure how it all looks on your end, but i have a standard flex fuel line segment a few inches long that i was able to securely fix, and then i put a threaded adapter at the end of the segment and put the fuel filter on that
Old Feb 18, 2010 | 12:27 AM
andrewmp6's Avatar
andrewmp6
You know its a inline 6 not a v6 right?
Old Feb 18, 2010 | 04:44 AM
tx65coupe's Avatar
tx65coupe
If its stripped out, you could try retapping the threads. If you do that you'll have to get all the metal shavings out of the carb before using it though.
Old Feb 18, 2010 | 11:08 AM
kalli's Avatar
kalli
there are those metal canister fuel filters in front. they are notorios for breaking at the solder. just replace it with a new one (you can get them for a few bob fifty from NPD etc) and see how that goes
Old Feb 18, 2010 | 06:42 PM
67 horse's Avatar
67 horse
thanks to all for your help on this one.
Old Feb 18, 2010 | 06:49 PM
FoMoJoe's Avatar
FoMoJoe
I would use either a retaining compound if it's completely stripped and is like pushing a tube in pipe, or some threadlocker if it has a few threads left in it. Should hold up with out a problem and seal her up. Just use a removable grade of either that you chose.
Old Feb 18, 2010 | 06:51 PM
FoMoJoe's Avatar
FoMoJoe
An industrial pipe sealant, similar to a threadlocker, would do the trick as well. I used some on my intake for the hose connector flange for the coolant.
Old Mar 23, 2010 | 11:12 PM
rjimenez's Avatar
rjimenez
Default same problem
My had stuff in side the carb inside where fuel fiter goes
Oct 26, 2015 05:01 PM
StalkerGT
Sep 25, 2015 02:41 PM
TfcCDR
Sep 14, 2015 12:08 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
5.0 kevo
Sep 3, 2015 06:24 PM
