proprtioning valve
Old Feb 25, 2010 | 09:31 AM
MonsterBilly's Avatar
MonsterBilly
Default proprtioning valve
SHould i mount it inside the car or under the hood?
Old Feb 25, 2010 | 10:26 AM
2+2GT's Avatar
2+2GT
Under the hood. You don't want hydraulics inside the car. Ford put them on the fender apron below the LH hood hinge, except early 67 had them at the rear axle hose under the car.
Old Feb 25, 2010 | 11:27 AM
kalli's Avatar
kalli
ya. i put mine very close to the master cylinder. I have a dual master cylinder which feeds front and back seperately. So that's the easiest way to mount them and the best place.
You only want the thing in car if you like to change your brake proportion during a race, and I think even that is a stupid idea *g*
Old Feb 25, 2010 | 04:35 PM
Cruzzar's Avatar
Cruzzar
I'm not sure how often you would need to adjust it under normal driving conditions once it is adjusted. I put mine under the MC. Drilled and tapped the MC, made a bracket and ran the lines. I also attached my line loc for the front brakes while I was at it.
Old Feb 25, 2010 | 06:32 PM
LastDeadLast's Avatar
LastDeadLast
Cruzzar,
That's a great looking setup!!
Old Feb 25, 2010 | 06:44 PM
64.5stanger's Avatar
64.5stanger
nice that is a one off custom setup! looks ti*tys
Old Feb 25, 2010 | 06:55 PM
ozarks06's Avatar
ozarks06
Show off! That is too cool.
Old Feb 25, 2010 | 07:27 PM
BigIron22's Avatar
BigIron22
What is that master cylinder from? I want to build that same set up.
Old Feb 25, 2010 | 10:35 PM
Cruzzar's Avatar
Cruzzar
The master cyl. is from a '94-'95 Cobra. It came with my 13" Baer brakes which will be non power assisted. Their catalogue lists two different sizes for that master cyl. The manual brakes should run the smaller .9375" bore while the power asst. would run the larger 1.00" bore. I only wish that the outlet ports were on the opposite side of the cyl. I thought about drilling and tapping the ports myself but I would have to completely disassemble the brand new unit. FYI, they are metric threads but this would not be a problem.
Old Feb 26, 2010 | 05:59 AM
ozarks06's Avatar
ozarks06
I'm using a 96 Explorer master cylinder which is virtually identical but the ports do come out the other side (to clear my valve covers).
