Electrical problem
I dont know jack about the 73s you could try pulling the connectors for the lights as well...If that doesnt solve the problem then the issue is along the wire anywhere just after the fuse box to just after the radio or turn signal bulbs...
Do you have a multimeter?
When did it last work right?
Did you do anything since then and now?
-Gun
-Gun
-Gun
-Gun
Thats indeed a possibility.
You might try the FAQ section here and look for a 73 wiring diagram.
Follow the wire path and see where they all go. The most likely spot for a short is at any load source such as a radio or at the blinker light housing AND anywhere the wire goes through a metal sheet or frame (the metal may rub into the insulation and contact the hot wire causing a short)
good luck
-Gun
good luck
-Gun
uberstang1
Sep 20, 2015 06:42 PM
ccdguy
Sep 19, 2015 05:20 PM
TfcCDR
Sep 14, 2015 12:08 PM
