measuring pushrods (hyd lifters)
Old Mar 16, 2010 | 10:14 AM
kalli's Avatar
kalli
Originally Posted by MBDiagMan
Use the lifters that you will actually be using in the engine for the test. The way you can do this is to use a "checking spring" in the place of your regular valve spring. The checking spring is a very light pressure spring. This will allow you to use the push rod length checker without collapsing the lifter.
well I got through to compcams and they advised the same. use a checking spring and add 50/1000" for preload ... bollocks. not really in any mood for organising checking spring and trying to find gear for changing valve springs ...
Kalli
Old Mar 16, 2010 | 10:40 AM
MBDiagMan's Avatar
MBDiagMan
Originally Posted by kalli
great idea, but as I understood you have to preload a lifter so that the lifter actually works. (~0.03"). so i probably have to add that later to the pushrod lenght?! anyway. I'll keep researching if there's a way without me having to change valve springs. i want to do at least 2 cylinders intake and exhaust side. so that means I need more tools ...
If i find a different method, I'll post it !!
For checking purposes, just squirt oil in the side of the lifter until the lifter is fully extended, then check with that. That will give you a pattern close enough to see if the length is correct or not. If you're .030 off from a perfect length push rod, you will be okay.
Old Mar 16, 2010 | 10:56 AM
kalli's Avatar
kalli
might just do that. however once done I'll check again with ordered pushrods installed if I'm good. just to make sure.
it can't be worse than just throwing in the stock pushrods in hardened version.
Old Mar 16, 2010 | 11:56 AM
MBDiagMan's Avatar
MBDiagMan
ABSOLUTELY! You should always recheck a cylinder after you have the final push rods in hand.
mtgldr
Feb 3, 2024 09:00 PM
Gene K
Oct 21, 2015 11:37 PM
jrrhd73must
Oct 2, 2015 09:17 PM
69Volunteer
Sep 30, 2015 10:39 AM
LivingInThePast
Sep 16, 2015 12:20 PM
