brakes
Old Mar 14, 2010 | 09:58 AM
ctango01's Avatar
ctango01
Default brakes
I got a 67 coupe v8. Stock now. Doing a complete frame up resto on it. I want to go to disc brakes all the way around. Sorta tight on cash. I was needing to know if there are any other vehicles that i can use the disc brake setup. Even if i have to change the spindels. Im a good fabricato.
thanks
Old Mar 14, 2010 | 10:12 AM
cdan03's Avatar
cdan03
check out fordmuscle.com in the forum section look at the tech exchange. there is quite a bit of brake installs for mostly less than 300 front and 300 rear.
http://www.fordmuscle.com/forums/braking-articles/
Old Mar 14, 2010 | 07:45 PM
ctango01's Avatar
ctango01
Thats that site really helped alot. I got a grand marquis and prob get my hand on some ford explorer parts also.
Old Mar 14, 2010 | 09:40 PM
Starfury's Avatar
Starfury
Why rear discs, especially if you're on a budget? They're overkill on a car that doesn't get driven on a track. I drive my '67fb hard with OE-style front discs and OE rear drums. It stops just fine.
For the fronts, I'd recommend the OE-style 65-67 front disc kit from CSRP. Unlike other swaps, it's mostly a bolt-on job that doesn't require replacing the spindles. Everything is OE, so getting replacement parts is a breeze. The only semi-difficult portion of the job is bending new brake lines. Time consuming, but even then it's not all that difficult.
Old Mar 14, 2010 | 10:40 PM
tx65coupe's Avatar
tx65coupe
I agree, just upgrade the front to disc and leave the rear drum.
Old Mar 15, 2010 | 12:52 AM
andrewmp6's Avatar
andrewmp6
Yeah the oem 4 piston are great brakes a little pricey but will out stop anything else oem you can use but the cobra brakes.
Old Mar 17, 2010 | 07:30 PM
ctango01's Avatar
ctango01
I think ill change the front with the discbrakeswap.com site. Then after i change them ill run it a while and change the rear. B/c its going to be a street strip car. Got a 351 to put in.
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
